newest version Art pipes
Old Feb 12, 2012 | 04:44 AM
  #46
GTX915's Avatar
if I'm correct, the xyz pipe replaces the y pipe right?
Old Feb 12, 2012 | 08:16 AM
  #47
Blue Dream's Avatar
I drove ttrank's car solo
Correct. It comes with 3 options for the extension; straight pipe, resonator, or HFC module.
Old Feb 12, 2012 | 12:45 PM
  #48
Aztec's Avatar
Yes
Old Feb 12, 2012 | 12:54 PM
  #49
Shanes_G's Avatar
does anyone in here have a straight pipe accessory?
Old Feb 13, 2012 | 12:35 AM
  #50
GTX915's Avatar
thanks. I'll be changing my setup for art pipes and xyz pipe with resonator in a few months
Old Feb 13, 2012 | 12:48 AM
  #51
Aztec's Avatar
I tried to take change out the resonator today, I strip one of the bolts...
Does anyone know what should I do? Should I just cut off the bolt?
And does anyone know the size of the bolt size and nut? I will need 2 new ones...
Old Feb 13, 2012 | 01:34 AM
  #52
Frankieg35's Avatar
Cut it or drill it out.. just match up the bolt and nut u didn't fukk up..
Old Feb 13, 2012 | 01:49 AM
  #53
Aztec's Avatar
Lol. I'm going to cut it off. It's going to take me a few weeks for me to get to it again. My parents are moving and I'm moving too at the same time. So i will be busy like a bee. I will keep y'all posted.
And when I tried to take out the resanator, I notice it was not line up right. When I fix that, the buzzIng sound from the art pipes hiting the heat shield, was less noticeable, big time. But I will keep y'all posted about that too...
Old Apr 7, 2012 | 02:07 AM
  #54
Aztec's Avatar
just a update, i have two jobs now, so it will take me a while for me put the straight pipe, but most likely i will have up rev do it because the driver side art pipe does hit the heat shield, it doesn't buzz a lot, but i dont like it. Im thinking around june that when i will take it in...
I will keep yall posted...
Old Mar 10, 2013 | 11:17 PM
  #55
Aztec's Avatar
It been a while since I updated...
I wasn't able to hook up the stright pipe..
Had to put on the MD cat converter. Got tierd of the smell. Sounds almost the same with the resanator. I was not able to drive much becuase I had other things to do.
I also don't have the buzzing sound from the art pipes no more...
I bought a electric impact wrench, so I can tighten the bolts of the exhaust, and change out the shocks and other things...
One note I want to add is , I keep geting a SES light for the pass few months now.. It says it might be oxygen senors or leak Exhust or MF sensor..
Will keep you posted..
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
