HR..Question
Old Jan 21, 2012 | 10:56 AM
ekrebs's Avatar
HR..Question
How do i know if i have a HR Y pipe? i picked up a 2008 350z Y pipe for $50 bucks last night but im not sure if its the "HR".
any thoughts??
Old Jan 21, 2012 | 11:03 AM
J2S2M's Avatar
If it came off of an 08 Z, I believe all 07+ Z's come with the HR motor. So what you have in hand should an HR pipe.
Old Jan 21, 2012 | 06:19 PM
ekrebs's Avatar
So im starting to think this deal on the HR Y pipe i got wasn't the best deal..There is some rust on the flanges and by the flex pipe, will this spread and be an issue or should i be ok?
Old Jan 21, 2012 | 11:58 PM
MikeTanabe's Avatar
Yup if it an 07-08 350z its an hr y pipe, and can you sand off the rust and coat it with some paint?
Old Jan 22, 2012 | 10:40 PM
Reidonly's Avatar
Post up a pic to be sure.
Old Feb 14, 2012 | 01:07 AM
ekrebs's Avatar
what about an HR y pipe from an 2010 370z?
Old Feb 23, 2012 | 07:21 AM
martyball619's Avatar
whats so good about the HR y pipe?
Old Mar 3, 2012 | 03:04 PM
Reidonly's Avatar
Pretty solid gains for a just being a slightly different OEM y-pipe on the cheap.
https://g35driver.com/forums/tuner-d...pipe-dyno.html
Old Mar 4, 2012 | 01:01 AM
DiGil's Avatar
Really, if it's only surface rust, sand it to get rid then paint to protect and you should be good.
Old Mar 5, 2012 | 03:29 PM
seymore4's Avatar
m56
the internal diameter is slightly bigger than the DE Y-pipe, pretty good upgrade on a budget.
I wouldn't worry about the rust... its exhaust. no big deal
Old Mar 8, 2012 | 03:57 PM
G35.fan's Avatar
I have an 06 sedan 6MT. Will any HR y-pipe be plug and play or are some modifications necessary?
