K&N Cold Air Intake
Old Apr 9, 2012 | 05:44 PM
Jamal_G35x's Avatar
K&N Cold Air Intake
Hey guys, I was looking at this intake for my 05 g35x:
Amazon Amazon
I was wondering if anyone has this intake? How much HP I will gain? How the install is and basically if you guys recommend this intake?
Thanks!!!
Old Apr 9, 2012 | 05:57 PM
seymore4's Avatar
m56
you won't see massive gains from an intake, you'll see about the same from a drop in K&N filter and z-tube. Intake's do look good tho
Install is pretty straight forward, should take around 30 mins if you have the right tools
Old Apr 9, 2012 | 05:58 PM
Jamal_G35x's Avatar
Do you know what it will sound like?
Old Apr 9, 2012 | 06:04 PM
seymore4's Avatar
m56
slightly more aggressive, deeper, no crazy change tho
Old Apr 9, 2012 | 06:06 PM
Jamal_G35x's Avatar
So the question is: should I get it?
Old Apr 9, 2012 | 06:26 PM
seymore4's Avatar
m56
sure why not, its a good price
Old Apr 12, 2012 | 06:34 PM
saywat?'s Avatar
u can get nismo cold air intake from g35parts.com for $233 + shipping
Old Apr 12, 2012 | 09:43 PM
LoSt180's Avatar
Stillen + Z-tube can be picked up for about that much and it has a nice air box around the filter so you're not sucking in hot engine bay air. That k&n one doesn't look like cold air to me..
Old Apr 13, 2012 | 09:55 PM
AZWoodG35S's Avatar
I went with a z-tube, revup venturi ring in stock box, and airaid synthamax non oiled drop in filter cause k and n sucks a big one. Sounds great and pulls good about 6 to 8 ponies increase! Try it on.
Old Apr 17, 2012 | 09:57 PM
Jamal_G35x's Avatar
Decided against the K&N because of heat soak. Went ahead and got the Stillen+ Z tube
Old Apr 17, 2012 | 10:17 PM
faiz23's Avatar
Dyno sheets for before and after or is it just a placebo effect / justify the purchase......
Old Apr 17, 2012 | 10:26 PM
AZWoodG35S's Avatar
You are right about placebo affect for sure no denying it. But its not like stillen or r2c or jwt claiming 12 hp. I built mine using the best stock parts and a great panel filter and not to forget maf cleaning, I swear by what I said earlier, there are gains to be had not much but gains none the less.
Old Apr 18, 2012 | 11:27 AM
That's G's Avatar
^ Not 6 to 8 ponies though. I have the same setup.
G35Rican
Jul 31, 2024 01:37 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
JLee301
Sep 25, 2015 08:46 PM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
