Cleaned throttle body now problems :( help
Old Apr 26, 2012 | 12:05 PM
Chris C.'s Avatar
Originally Posted by mpugeda
Then I would keep trying the reset procedures. Some people can do it in 5 mins, some people needed 2 hours lol. Did you touch the MAF at all? I'm assuming you read the other TB cleaning threads?
Edit: make sure you're car is at operating temperature. i.e. drive around for 10 mins or so pull in, then start the reset procedure. You can sit in your car all day and execute perfect timing during the reset but if you're car is cold you won't have any success. The ECU reset can be performed when car is cold.
This.
Not only does the engine need to be at operating temperature, but the transmission as well... at least for automatics that is.
Old Apr 26, 2012 | 12:17 PM
Cabos G35 Coupe's Avatar
Ya mines 2004 auto coupe
Old Apr 26, 2012 | 12:20 PM
mpugeda's Avatar
Assuming you used the proper MAF cleaner, you should be straight. Drive around, warm it up, do the relearns.
Old Apr 26, 2012 | 12:28 PM
Adon's Avatar
sucks, but did you do any research on this forum about this before doing it ?
If so you would have found out that this is a common issue when messing with the throttle body, you have to do the reset like these guys said but it isn't as easy as it seems.
my local dealership was doing some warranty work for me and actually messed up the throttle body and had to hold my car for a few days while they tried doing this procedure few different ways...
anyway good luck
I used the crc products one for maf sensor one for tb
Old Apr 26, 2012 | 12:31 PM
JaE35's Avatar
Moderator
G35 Sedan
definitely not touching my throttle body..it'll have to die on me lol, i use the crc maf cleaner all the time, never an issue
Old Apr 26, 2012 | 12:37 PM
tylerxfire's Avatar
sounds like its ur cat clogged up..take the cats off and check em out.
Old Apr 26, 2012 | 12:43 PM
mpugeda's Avatar
OP said his car was running fine pre-TB & MAF clean.
Old Apr 26, 2012 | 12:48 PM
I bought some used ones with only 15k on them maybe ill swap them and see... But my cats where good before I took out and cleaned the tb and maf this happened right when I turned on the g
Old Apr 26, 2012 | 12:51 PM
mpugeda's Avatar
word. update when you try it with the car warm.
Old Apr 26, 2012 | 01:00 PM
Yessir ima do that drive for 15 min then the reset
Old Apr 26, 2012 | 01:06 PM
tylerxfire's Avatar
so if the car was fine then why did u do the tb cleaning?
could just be coincidence and the cats time..does the car start right up and rev up and everything? what about idle?
Old Apr 26, 2012 | 01:28 PM
I did the tb cleaning because it was idleing low to point car might shut off put if I press gas it would stay on normally so I thought cleaning the tb might help. My car starts right up but sounds like $hit if Im inside the car while on you can hear the doors rattle from the exhaust since its not breathing right
Old Apr 26, 2012 | 03:38 PM
tylerxfire's Avatar
so as i suspected that everything wasnt perfect berfore doing the throttle body cleaning. maybe the car was acting the way it is because of the cat from the beginning..
well as others have stated id do the relearn procedure. which may solve ur problem...i did this a few weeks ago on my first try with a watch with a second hand. just try that and if it doesnt work id still say its the cat or cats...
Old Apr 26, 2012 | 03:53 PM
  #30
mpugeda's Avatar
Might be time for some Motordyne ART pipes
