Spacer, MREV2 or both??
Old Aug 15, 2012 | 09:03 AM
TheJanitor6203's Avatar
I've got a 2006 RevUp engine with a 5/16 spacer. I was about to buy a MREV2 to go with it because I thought that the combination was the best hp gain. I've seen the dyno linked from the motordyne website but I can't find any other info. I was recently told that I only need one or the other and that the combination of the two isn't worth it. So the question is what provides the best hp increase: a 5/16 spacer alone? MREV2 alone? or both together?
Old Aug 15, 2012 | 09:16 AM
jninja26's Avatar
The answer is both. Whoever told you that the combination isn't worth it (HP or money?) may not be well informed. I personally don't have an MREV, but I know people who do.
Old Aug 15, 2012 | 09:31 AM
JaE35's Avatar
Moderator
G35 Sedan
from tony at motordyne
Originally Posted by Hydrazine
Hi WhiteonWheat,
I don't recall using the words "Massive gains" to describe the MREV2/spacer combination, but when used on a REVUP engine it will certaintly be the best bolt-on short of nitrous or FI.
It will make a minimum of 15HP/18TQ in the upper midrange. Many people have dynod in excess if 20HP/30TQ.
Old Aug 15, 2012 | 01:19 PM
irishsig's Avatar
MREV2 & 5/16 spacer was one of the best breather mods Iv'e done to my car.
U can really feel the power diff in the higher rpm ranges.
Well worth the money, esp if u can buy them used. Def get both.
U can prob get the MREV2 used for about $350 and with some patience u can do the install yourself.
Old Aug 15, 2012 | 01:38 PM
falcor's Avatar
the spacer on your 06 isn't doing anything for you without the MREV2... Call Tony at MD, he'll explain it to you.
Old Aug 15, 2012 | 02:21 PM
Xet's Avatar
Xet
Tony has a lot of posts on here about it, but for simplicity:
1. Spacer alone is great for non-revups
2. Spacer alone on revups doesn't really do anything
3. MREV2 does nothing for non-revups, but is AMAZING for revups
4. Spacer + Mrev2 for revups adds a bit more even
Old Aug 15, 2012 | 02:27 PM
Thanks for all the input everyone. This everything that I thought I already knew but after talking to that guy yesterday I was questioning all of it.
Old Aug 15, 2012 | 02:33 PM
seymore4's Avatar
m56
Agreed with everyone else, get both, and a Z-tube/ K&N filter to free up the intake side. next best mod is going to be a $300 Osiris reflash to remove the electronic throttle restriction and reset the fuel targets.. From then on it gets expensive
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
