Pop charger vs. RevUp box
Old Sep 19, 2012 | 11:28 AM
TurTLe*'s Avatar
Originally Posted by saywat?
i dont recall there ever being dyno runs with revup vs non revup airbox to prove its effectiveness.
dynos when measuring such small amount of increase won't be solid proof. I've seen dyno's on back to back runs show as much as 5% increase/decrease.
The best person to ask would be motordyne. He has a inhouse or close to a inhouse dyno. I he posted a WHILE back that OEM setup made the most power, hence why there is no MD intake only exhaust and plenum mods.
Old Sep 19, 2012 | 11:40 AM
gary c's Avatar
If your concern is how well your Infiniti runs the choice is obvious....revup box. With the pop charger the minute it gets warm will cost you hp due to the metal construction and exposed filter. Our VQ motors absolutely love cool air, if you can redirect air from the grille to the box that works even better SEARCH....Gary
Old Sep 19, 2012 | 12:01 PM
faiz23's Avatar
Rev-up cause it was free and comes with my vehicle factory . Z-tube since it was only $20 from a local my350z member and a high flow dry air filter for less than $36 to provide plenty of airflow and will not effect MAF due to dry filter versus oil. $56 for rev-up with z-tube and a new airfilter and all this will actually help with ensure sufficient cool airflow at all times. Instead you want to spend double and get something that makes a noise and actually robs you of power after driving in the Texas heat or after hard runs when heatsoak kicks in. Search is your best option for you to decide between cost, effect, gains/loss and availability, which one you prefer ?
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
