catalytic converter removal.
Old Nov 19, 2012 | 11:33 PM
Texas-G's Avatar
has anyone ever removed them? i removed mine because i think they were clogged the car responded waay better and sounds better however now im trying to find some replacement ones car is running really rich but i dont know if thats the cause of it? any help or imput would be appreciated.
Old Nov 27, 2012 | 02:06 PM
amc5769's Avatar
catalytic converters being clogged can cause the car to run rich/lein
when your exhaust gets clogged up or old or even 02 sensors going bad, your ecu is going to tell your fuel system to inject more/less fuel into the cylinders. This is because your o2 sensors create a number, also known as emissions, which is % of smog over oxygen in the exhaust. When your exhaust is clogged, or opened up (use of a test pipe) you're going to get many different numbers, so your ECU tries to adjust fuel trim and injector latency to create the ideal %
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
JustinMKN1
Sep 18, 2015 03:40 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Hawk196
Sep 10, 2015 10:37 AM
