Greyish Smoke Coming From Exhaust
Mar 28, 2013 | 02:52 PM
So I recently got an exhaust system, (dynomaxx)whatever that is. But after having it for about 2 weeks ive noticed some type of grey smoke coming out of the tips when I rev it. I also noticed that it sounds way different than when I first got the exhast. Is there something wrong with my car?
Reply 0
Mar 28, 2013 | 03:30 PM
is it cold?
moisture?
Reply 0
Mar 28, 2013 | 03:43 PM
Quote: is it cold?
moisture?
The car isn't heating up if that's what you mean, and if your talking about weather.. than yeahh it was cold and now kinda humid. I touched the tailpipes and black dust got on my finger? The gas mileage went down too
Reply 0
Mar 28, 2013 | 03:45 PM
black dust is pretty normal. that's pretty much built up exhaust gas. the inside of my tips are black.
do you notice a smell to the smoke? sweet or anything
Reply 0
Mar 28, 2013 | 04:06 PM
Quote: black dust is pretty normal. that's pretty much built up exhaust gas. the inside of my tips are black.
yeah, It kinda smells like gas im not sure sweet tough. even when im driving it I sometimes notice the smell.
Reply 0
Mar 28, 2013 | 04:07 PM
if the gas is strong, there might be a leak in your exhaust.
Reply 0
Mar 28, 2013 | 04:13 PM
Quote: if the gas is strong, there might be a leak in your exhaust.
I should take it to the muffler shop again then?
Reply 0
Mar 28, 2013 | 04:19 PM
if possible, check that everything is tight yourself.
either way, if something wasn't tight. it wouldn't cause grey smoke to come out of the exhaust.
unless that smoke was condensation in the first place, and nothing to worry about.
Reply 0
Mar 28, 2013 | 04:21 PM
by the way, does this exhaust come with test pipes. if you're not sure, post a picture of the setup.
Reply 0
Mar 28, 2013 | 04:25 PM
Quote: by the way, does this exhaust come with test pipes. if you're not sure, post a picture of the setup.
How do I check a leaky exhaust, and Thanks You for helping me out man means a lot. ima post a pic
Reply 0
Mar 28, 2013 | 04:26 PM
All the flanges (sections where two pipes meet), check if any bolts are loose or missing.
Reply 0
Mar 28, 2013 | 04:28 PM
If the setup came with test pipes or high flow cats, that could explain the smell. Which would be normal for test pipes/HFC. (test pipes having a lot stronger smell)
But it wouldn't explain the grey smoke. Which at this point, I'm assuming to be just condensation.
You could check your oil cap and see if it's a milky substance or check your coolant level to see if you're burning any.
Reply 0
Mar 28, 2013 | 04:54 PM
Quote: If the setup came with test pipes or high flow cats, that could explain the smell. Which would be normal for test pipes/HFC. (test pipes having a lot stronger smell)
Its a true dual, and I didn't see any bolts loose.
Greyish Smoke Coming From Exhaust-exhaust.jpg   Greyish Smoke Coming From Exhaust-exhaust2.jpg   Greyish Smoke Coming From Exhaust-exhaust3.jpg
Reply 0
Mar 28, 2013 | 05:03 PM
looks fine to me. looks like you have the oem catalytic converter. so i don't see where the smell could be coming from.
Reply 0
Mar 28, 2013 | 05:04 PM
the smoke is probably just condensation, unless you can take a video
Reply 0
