K&N CAI Noob needs help please, hard start
Old Aug 5, 2013 | 02:09 PM
damman98's Avatar
Is it possible that a K&N CAI could cause a starting issue on 2003 G35 sedan? I bought the car with the intake already installed so I have no idea if this is the issue but it seems to make sense to me. I have removed it and checked for leaks, something unplugged, found nothing obvious.
The actual symptom is that the car turns over for like 5 seconds before it fires up.
Any ideas would be appreciated.
Old Aug 5, 2013 | 02:59 PM
Xet's Avatar
Xet
Is the filter clean? Might be worth it to clean it as well as do the battery reset, but I would doubt a cai would cause your issue
Old Aug 5, 2013 | 03:03 PM
damman98's Avatar
thanks for the reply. I looked up battery reset on a G35 and the consensus seems to be about 8 hours. Is that true? Also, any sensors that i need to focus on? Seems like no fuel is or at least a bad mixture for a few seconds.
I already replaced the spark plugs with NGK Iridums, based on my research here.
Old Aug 6, 2013 | 01:10 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like either you have a fuel issue or one or both of your crankshaft position sensors is starting to go out. More than likely isn't an intake issue.
Old Aug 6, 2013 | 09:18 AM
damman98's Avatar
Ok, you said crankshaft position sensors? I can only see one. Do you mean camshaft position sensors? I see 2 of those.
I agree it makes sense that something like this could cause my issue. Just wondering which is more likely.
Thanks
Old Aug 9, 2013 | 10:17 AM
damman98's Avatar
Can someone verify?
1 crank sensor
2 cam sensors
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
miata007
Aug 17, 2015 04:36 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mcneil_g35
Aug 5, 2015 12:03 PM
