Y Pipe Problem
Old Sep 15, 2013 | 11:05 PM
FL850's Avatar
Y Pipe Problem
(Skip to the bottom if you could care less about my introduction)
Hey everyone. I recently bought a 2004 G35 coupe and couldn't be any more happy with my decision! What influenced me to buy the G35 was not only the look but the sound of the exhaust. So I pretty much wanted to make the exhaust a little bit louder and took the Z-Tube/K&N Filter drop with Rev-up Airbox route. I also bought a HR Y-Pipe and then...
The "I Hate You Gods" decided to rust the **** out of my under body so I couldn't remove my bolts. I tried soaking them in PB Blaster and WD-40 every 10 minutes but unfortunately that didn't work. So my question is, can I just cut the existing y pipe off and weld the HR Y-Pipe on? Is it even worth all the trouble because I heard it just gives the coupe a slightly deeper louder growl?
Old Sep 15, 2013 | 11:08 PM
Urbanengineer's Avatar
Is it worth it to you? I like the way mine sounds (stock).
Old Sep 16, 2013 | 03:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
Just cut off the bolts and leave the y-pipe alone. Honestly it makes a small difference in sound and performance so it's up to you what's that worth financially.
Old Sep 16, 2013 | 07:21 PM
FL850's Avatar
Thanks guys. I honestly think it'll be worth it because any other exhaust mode will alter the exhaust note. I'll probably just go ahead and cut off the bolts.
Spartan268
Aug 20, 2015 09:14 PM
gatorglaze
Intake & Exhaust
Aug 17, 2015 02:16 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
