Check engine light, Loss of power after removal of Fuel rails ad injectors
Old Jul 30, 2014 | 11:37 PM
dboles84's Avatar
So, I took my upper and lower plenums and manifold off to clean them. In order to pull the manifold off I had to disconnect the fuel injector harnesses and fuel rails. The check engine light has come on after I reassembled the induction parts ad started it up.
What do you guys think? Could it be a bad gasket, incorrect torque o a bolt or something wrong with injection system? Any help is greatly appreciated!
Old Jul 31, 2014 | 12:01 AM
hurleyguys's Avatar
pull the codes it could be a number if things. be sure to check all of the tubes you pulled off, to see if you didnt connect or whatnot.
Old Jul 31, 2014 | 11:59 AM
dboles84's Avatar
Well checked all the hoses and connectors and they are all attached. I'm worried that it might be a fuel injector.
Muski_G
Dec 1, 2023 11:11 AM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
