Test pipe
Old Apr 19, 2015 | 10:55 PM
Ingrassia22's Avatar
Test pipe
Hi guys, recently I have put on berk test pipes with my Invidia Gemini exhaust. At fist I wasn't throwing a code but now it came on the next day, most likely due to catalytic deficiency.. Just curious as to if I should get it tuned, for one, to make the code go away and two, if deleting the cats will have any negative affect on my motor or anything of that sort if it isn't running right.
Thank you!
Old Apr 19, 2015 | 11:28 PM
gary c's Avatar
Welcome to Driver Ingrassia!
Only negative effect your test pipes will have is on our environment! Most auto parts stores will let you know what error code you're getting. Error code is probably a sensor or it could be Berks bungs aren't deep enough, that's where the sensors are screwed into. Search test pipe install for more information...Gary
magnetism80
Jan 27, 2016 12:57 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
