Use a single HFC after Y-pipe
Old Jul 27, 2023 | 09:05 AM
Urbanengineer's Avatar
Tony mentioned running no cats until after the engine break in was finished. Makes sense. Lots of assembly lube when putting it back together.
Old Jul 27, 2023 | 10:48 AM
seymore4's Avatar
m56
I planned to keep the downstream sensors in the art pipes, do you think that will cause codes because of the downstream restriction?
Won't know until you do it... ART pipes are always a toss up
Good idea
Old Aug 21, 2023 | 04:20 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I've seen HFC's mounted completely at the rear, basically mounted where the mufflers would usually be. It's not a bad location too since there's a lot of room and plenty of factory installed heat shielding. These cars didn't use a muffler though, resonator and HFC only.
The only downside would be routing the wiring for your downstream sensors, I'd pull it back up into the cabin, route through the interior to the trunk, then dive down to the underside of the car. I don't know if it would affect tuning out efficiency codes (I doubt it) but maybe @seymore4 could shed some light on if there's any issues with that far of a distance between upstream and downstream sensors.
I did that with a 455 swapped '77 Cutlass. Lived in Arizona at the time and they'd decided if you failed a tailpipe test, even if just adjusting the carburetor would correct the issue, if you didn't have cats, you'd have to get them too. So put them where the mufflers were. The guy at the shop who did the work said to make sure to drive the car around and then leave it running while waiting for the inspection to make sure the cats were hot enough to do their job (that's why OEM cats are close to the engine) and I'd pass. Which I did. But there wasn't an O2 sensor issue with cars from the 70s.
Old Aug 22, 2023 | 10:31 AM
ART pipes don’t tend to throw codes, so I am hoping I will be okay.
I’ll run without them during the break in period and then install after the break in is done.
Old Aug 22, 2023 | 10:40 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
6+ years in with them, no codes.
rich2342
Intake & Exhaust
19
Apr 16, 2014 05:56 PM
Dablakbradpitt
Engine - Exhaust
Apr 30, 2013 04:35 AM
blackg356spd
Engine - Exhaust
Aug 15, 2011 08:45 PM
