Test pipes, easy install?
Old Mar 9, 2005 | 02:50 PM
azcougarman's Avatar
What I use as a breaker bar is an old clicker-style torque wrench--because it's big and it ratchets. Even when this thing was new it was not very accurate so I quit using it as a torque wrench and now use it primarily as a breaker bar.
As for using a torque wrench as a breaker bar I have always heard it was okay to do so as long as you do not exceed the maximum torque limit of the torque wrench when breaking a nut loose. If this is not the case why then do torque wrenches have scales on both sides of zero? And why does clicker-style torque wrench have a reverse mechanism if it should not be used in reverse? Just curious as to your thoughts on this.
Old Mar 9, 2005 | 02:56 PM
copbait's Avatar
Originally Posted by neffster
NEVER use a torque wrench to break bolts loose. If you take that same torque wrench and have it re-calibrated you will probably find that it is off by more than 10%.
Well of course if you exceed the specs of the torque wrench then you may knock it out of calibration, but yea now that I think about it it's probably a bad practice to use them for breaking bolts
Old Mar 13, 2005 | 12:04 AM
ChuckP's Avatar
neffster, i completly agree with the install, if you can get it done by a shop for 50 then do it. Only problem, both reputable exhaust shops i know both said they wouldnt do it casue of legal issues even after i assured them the car was for the track use only.
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Ray Feta
Aug 13, 2015 11:40 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
