MAF problems
Old Dec 18, 2019 | 05:43 PM
BadGondeck's Avatar
Red G35 stillen catback
MAF problems
So I my g35 03 is in limp mode with a p0102 and occasionally a p0113.
I have swapped the maf and even checked it on a Sentra which uses the same maf and it works fine. I also cleaned the maf and throttle body.
I'm hoping someone else here knows where I can go from here and any possible solutions.
Old Dec 19, 2019 | 10:24 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
That's odd, both errors are your MAF sensor:
P0102 - Low MAF output voltage
P0113 - High IAT signal (also part of your MAF)
I would break out the FSM and check voltage at the MAF wiring. I would also use a scanner and see what grams/sec or voltage your MAF reads and if it changes with throttle. Sounds like a wiring problem if you have already swapped the MAF sensor.
Old Dec 20, 2019 | 10:56 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Unplug the harness and inspect it, if the code doesn't go way replace the MAF. You don't need to buy the entire housing, if you get just the sensor it's a lot cheaper. I think the Hitachi part number was MAF0031 and the sensor itself is around $50 usually.
mjgerstner4
Jul 25, 2019 11:41 AM
Learned Hand
Aug 4, 2018 08:54 PM
chuckd05
Archived Sales
Mar 8, 2009 09:00 PM
wan2hmp247
Aug 21, 2006 06:57 AM
qmaster8
Nov 11, 2005 05:38 PM
