Too much plenum Space?
Old Dec 18, 2020 | 02:03 AM
steve conyers's Avatar
g35 manual
Too much of a good thing? Has any one one tried or know if it's possible to use an aftermarket upper like a Kinetix Racing V+ intake along with a spacer? I'm thinking it would work great with a turbo, but what about NA?
Old Dec 18, 2020 | 01:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Clearance issues with the strut tower brace is usually why. However Tony at MD had some dyno results that the OEM spacer thickness being larger started to reduce midrange torque pretty significantly, depends on WHERE you want to make power and 5/16 was the happy medium for daily driven vehicles.
The greatest strength of this chassis is the handling, you wouldn't want to sacrifice that for a possible 2-3 hp.
Forced induction is a whole different scenario though since your intake restrictions aren't normally a problem at that point even with the stock no-mods plenum. Getting air OUT OF the engine is usually the most restrictive factor for FI.
Old Dec 21, 2020 | 09:19 PM
C_infty's Avatar
G35C M/T
Usually more plenum volume helps max power (smoother flow through the throttle and such increases flow at high speed when they become restrictions), but it takes up space and transient response is worse without ITBs or with forced induction since the bigger plenum takes more air to pressurize.
SnglTrboG35
Intake & Exhaust
16
Mar 9, 2014 07:39 PM
CannonGentry
Intake & Exhaust
Jan 31, 2013 02:30 PM
Gfast
May 26, 2008 10:32 PM
ducati999
Mar 7, 2006 12:17 PM
hyperlitesmu
DFW G35 Owners Club
Nov 8, 2005 01:11 AM
