Stillen+test Pipe=?
Old Apr 29, 2005 | 10:14 PM
g35kid18's Avatar
Stillen+test Pipe=?
does anyone have test pipes on there stillen exhaust if so how much louder did it get after you put the test pipes on and did you feel a lot of difference with the test pipes power wise?
Old Apr 30, 2005 | 12:50 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
What's more important to you, loudness or performance?
If you want loud, go with the test pipes. If you want performance, your better off going with the high-flow cats.
I've been told that you'll probably lose a little power with the test pipes unless you have a turbo or supercharger.
Just my 2 cents.
Old May 1, 2005 | 03:57 PM
MrBillMartin's Avatar
not sure about losing peformance with test pipes. never heard that.
i have test pipes now on my stillen exhaust and i am saving up for a set of highflows. i dont like the sounds of the test pipes. its not that they are loud, its that they are so raspy that it sounds like a rattle. friends have told me that it sounds like something is wrong with my car. i dont recommend test pipes. plus it makes your car smell like a zamboni.
Old May 1, 2005 | 05:24 PM
1nate7's Avatar
I don't think you will notice much of performance difference unless you have a very sensitive butt dyno. Test pipes will significantly increase the sound level on any exhaust system and if you get them I highly recommend the resonated ones to help elimate the rasp MrBillMartin mentioned. They do smell too, but I only noticed it at idle with the windows down and it wasn't overpowering.
Old May 1, 2005 | 07:02 PM
g35kid18's Avatar
i really love the way the stillen exhaust sounds. I wouldn't really bother me if it gets louder i just dont want to lose power i was looking at the test pipes cause i heard on different threads that test pipes where adding power to their cars is that not a true statement?
Old May 2, 2005 | 11:52 AM
the stock cats are detremental to exhaust flow. before the exhaust fumes get to your cat back exhaust the are hitting a brick wall (your stock cats). any sort of high flow cat, or test pipe resulting in better exhaust flow means added power. problems arise with losing peformance when there is too little back pressure. but i dont think that is an issue with the test pipes on our car.
Old May 2, 2005 | 12:55 PM
jnkirk1974's Avatar
What MrBillMartin just said is what I was speaking about. The G35 DOES require a certain amount of back pressure (no, that isn't necessarily a bad word).
The question is, how much back pressure does it require and will the test pipes put you under what the required amount is.
Again, I don't know whether or not the test pipes will put you under the required back pressure or not. I'm just pretty conservative when it comes to stuff like this. My vote would be for high flow cats......just to be safe.
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
