GReddy Evo II fitment problems.
Old Jul 27, 2005 | 07:39 PM
G spot's Avatar
Ok, so I installed the GReddy Evo II exhaust a couple weeks ago. Ever since, it appears as if it's not straight in relation to the back bumper. Meaning the right side sits lower and farther out than the left side which is higher and doesn't stick out as far. I found a pic off another pic which shows what I'm talking about.
Also my rear stillen sway is rubbing on the exhaust because of it, at least I think that's the reason. I'm not sure how I could have possibly installed the exhaust incorrectly.... any one else have this problem?
Does it matter what side the flex tube is on the Y pipe? Right vs. Left?
Old Jul 27, 2005 | 10:30 PM
beastie's Avatar
My flex tube is on the right and doesn't rub on my Stillen sway. Also, you need to add spacers to make the tips even.
Old Jul 28, 2005 | 12:14 AM
G spot's Avatar
spacers?? how long and where? I wonder why my stillen sways are rubbing... what setting do you have the rears on? If anything, if I can't get it solved, we could hopefully meet up considering I'm in St. Pete too. Let me know. Do you have any pics of your undercarriage?
Old Jul 28, 2005 | 12:37 PM
socalsean's Avatar
So...I'm a bit confused...its that a pic of your car on the lift?
The sways might rub. You never know what might happen when you put aftermarket parts on your car which weren't designed to be put installed together. Take some better pics and someone should be able to help you out!
sean
Old Jul 29, 2005 | 12:13 AM
beastie's Avatar
zfever in tampa had some metal gaskets that provided enough width. When are you going to be in ST Pete?
Old Jul 29, 2005 | 01:52 AM
G spot's Avatar
I live in Treasure Island till mid August when I am goin back up to school.
Old Jul 29, 2005 | 09:49 AM
beastie's Avatar
PMed you.
Old Aug 5, 2005 | 01:41 PM
PearlWhite03's Avatar
That is weird. I have no prob with my Evo2.
KruZZe
Feb 27, 2023 05:04 PM
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
the93owner
Oct 4, 2015 09:40 AM
Ohsixgee35
Sep 16, 2015 04:33 AM
