Got a service engine when i put on my headers/cats
i just finished installing DC headers this weekend and also have crawford cats..........no ses light here........i remember reading other threads and others have suggested checking the O2 sensors
that's what I've heard from header installs, carefull with those O2 sensors. even if they were reinstalled properly, they could have been damaged when removed, or when they were off while the new setup was being installed.
Good luck! hope it's a simple fix like this.
If the cats you installed are cat deletes, you will have to do modifications on your o2 sensors(do a search). If you have crawford or other decent high flow cats, you probably damaged one or both of the o2 sensors(like the above responses stated).
