Anybody gut out their cats instead of HF?
i did that recently on the coupe. def felt power gains, car pulls stronger. compared to test pipes it keeps its backpressure (bc i didnt gut all of the, left some little part in) exhaust sounds stock but louder on WOT a bit throatier. however i get this weird ticking. i think i may have punched a small hole in it while using a freaking air powered chisel
Well when you go to sell your car in the future you'll need the car to be 50 states emissions legal. Each stock cat is ~$850 so if you want to save a few hundred now and end up spending $1700 later (or risk jail time or thousands of dollars in fines) that's your call.
just go for the crawford or kinetix.... i think neffster is right.... leave the stock cats alone.... too expensive to experiment with.....
A) i just bout a pair of used cats from a member on a forum. off a 350z. still have stock cats.
B) Its not just a random piece thats left in there. There are two parts to the cat. The major chunk of the cat i removed. there is a small portion still left in there. it is the 2nd part that i did not remove. I do not have a bad smell, and im pretty sure car will still pass smog. and still impressive gain
seagrasser
May 3, 2022 09:43 AM
magnetism80
Jan 27, 2016 12:57 PM
