Y Pipe Help!!!!!!
Old Nov 24, 2005 | 02:46 AM
dannyboi2088's Avatar
Y Pipe Help!!!!!!
im not sure if anyone will know the answer to this question but...........................does anyone know which y-pipe will fit the apex-i N1 exhaust?!?!?!
if anyone has any imput it would be great
Old Nov 24, 2005 | 05:08 AM
PhxBlue's Avatar
Polyester Pileup FTW!
Does the flange on the Apex-i line up in the same spot as the oem flange does? If so all of them will fit as far as bolting up to it goes.
Old Nov 24, 2005 | 02:26 PM
ohh thanks yea everything lines up in the same spot to fit the OEM
Old Nov 24, 2005 | 11:29 PM
SI_G35Coupe's Avatar
you should pay attention to pipe diameter when matching your exhaust to a Y-pipe, as the diameters vary widely by brand. if you exhaust uses smaller piping than your Y-pipe it will create a restriction
my Fujitsubo Y-pipe, for example, has a 76mm outlet. tanabe has like 70mm i think. those are the only 2 i know off hand
Old Nov 25, 2005 | 07:16 PM
TedRuxpin's Avatar
JIC is 76.3 outlet or 80mm outlet.
Old Nov 26, 2005 | 03:34 PM
Dieselnuts's Avatar
what is stock dia.?
Old Nov 27, 2005 | 02:54 AM
stock diameter is 60mm i believe, but someone correct me if i'm off
Old Nov 30, 2005 | 11:34 AM
G35StrongMan's Avatar
I have my stock exhaust in the garage.
Y-pipe is 55mm (2.17") to cats and 65mm (2.56") to midpipe.
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
