Best sounding exhausts
Old Dec 16, 2005 | 03:45 PM
IlirG's Avatar
Originally Posted by SI_G35Coupe
exactly what i did... i got headers, cats, and a Y-pipe... sounded like a stock exhaust on 'roids. but there was definitely a restriction in flow where my 76mm Fujitsubo Y-pipe met the 60mm stock midpipe. i have since added the Legalis-R and couldn't be happier with it. if you need clips when you get your sound working lemme know i have plenty
i wouldn't bother with the headers unless you're after every last HP you can from the exhaust... the gains aren't really worth the massive PITA of installing them unless you're trying to push lots of NA hp out of it
Hey thanks bro, im heavily leaning toward the Y-pipe Fujibutso R-Legalis setup.
Sorry for dragging this thread, but one more question. I most likely am going to be going with a Single Turbo kit this spring, which of these exhausts would be compatible?
Thanks again
Old Dec 16, 2005 | 04:19 PM
CarFanatic56's Avatar
Tanabe sounds good
Old Dec 16, 2005 | 07:29 PM
SI_G35Coupe's Avatar
single turbo is no problem with the Fujitsubo Legalis-R.... single turbos eliminate the cats and Y-pipe though, so the downpipe from the turbocharger will run directly to the spot where the Y-pipe formerly ended
Old Dec 16, 2005 | 08:49 PM
IlirG's Avatar
Awesome, thanks for the info I appreciate it.
Old Dec 16, 2005 | 09:39 PM
jimmytango00's Avatar
doesn't Kamal34 have a twin turbo setup? if so, the exhaust may sound very different on a NA car with stock headers, cats, etc.
yeah he does but i dont think his turbos are working. you think the sound is completely diff on n/a?
Old Dec 18, 2005 | 03:24 AM
yes believe it or not running a turbo setup will quiet down a car considerably... working or not the turbines block alot of the sound.
i guess you could get a general idea of the sound from his car... i just wanted to warn you that it might not sound exactly the same on your car
it's also worth noting, if you're planning on going with the turbonetics single kit, there have been some people having issues lately with aftermarket exhausts causing the system to run alittle leaner and overboost slightly.... are you planning on running the turbo with the default tune or are you going to get it dyno tuned after installation?
Old Dec 18, 2005 | 01:13 PM
IlirG's Avatar
I plan on taking whatever steps necessary to having everything "just right". Thats why I want to make sure I get a really good shop to install it, and deffenitely get my engine tuned.
I think instead of going with an aftermarket exhaust right now, Im going to wait until after I have my turbo installed and see how it works with the stock exhaust.
Old Dec 18, 2005 | 02:13 PM
MJ_G_35's Avatar
HKS is the best
Old Dec 18, 2005 | 02:47 PM
michaelmyers's Avatar
Hey what do you guys think of this combo? Looks like the hks but its a different company? Think it will sound just as similar, plus its 3in which I would love to go with when I go turbo?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Old Dec 19, 2005 | 04:50 AM
^they look nice, but hows the quality of Megan Racing?
Old Dec 19, 2005 | 05:22 AM
NDG35CHO's Avatar
How come it's not good to have the HKS Hi-power exhaust if you plan on going FI?
Old Dec 19, 2005 | 05:45 PM
Down_Shift's Avatar
Single turbo does not work with true dual exhausts.. And I'm not too sure how open the HKS is as of right now (hence why I sold it)
The Megans are pretty nice. They are definately cheaper than buying 2 HKS hi power cans! My buddy has em on his Z.. Looks good and gives the option of custom, which will be almost the same price as some other exhausts..
Have you looked into the N1 or WS? I've been looking at those as a temporary exhaust on my car (I have no exhaust on my car right now lol).. Holding out on a 3" since there's been some TN kit problems on the Z forums.
Old Dec 19, 2005 | 06:04 PM
Dieselnuts's Avatar
Just from the clips ive heard, i like the nismo.
Old Sep 3, 2008 | 01:35 PM
Maverick Hunter's Avatar
Big up for the Bassani exhaust
Old Sep 3, 2008 | 02:13 PM
  #30
Skaterbasist's Avatar
Retired SuperMod
Why bump a 3 year old thread?
