Removing the intake resonator (part #8)
Old Dec 30, 2005 | 02:31 PM
g35rcr's Avatar
to take #8 off...remove the wheel, fender liner...then the bolt is right there...makes it easier...
Old Dec 30, 2005 | 02:36 PM
MBentley's Avatar
Originally Posted by 99atlantic
...However, maybe if you do lift #10 straight up and out you can see/reach it.
That's correct. Once you lift that piece out you can reach in and grab it. I didn't remove the bolts that hold number 8 if I remember correctly. They kind of keep it in there w/ tabs that look like a sideways U. You can just slip if off once the bolts are loosened. Just feel around and you'll see what I'm talking about.
Old Dec 30, 2005 | 03:09 PM
99atlantic's Avatar
Did you notice any changes in sound once you removed it?
Old Dec 31, 2005 | 03:00 AM
MBentley's Avatar
I replaced the box w/ a JW pop charger, so I can't really comment on the sound w/ the stocker. I can say that the JW gives me wood every time I drive the car and that's w/ the stock G tube.
Old Jan 5, 2006 | 08:51 PM
99atlantic's Avatar
Old Jan 6, 2006 | 11:39 AM
MBentley's Avatar
Performance wise I can't say that I noticed much of a difference. I did seem to pull harder between 2k and 4k, but off the line I actually felt a slight decrease. Not a decrease enough to be concerned w/ it, I just noticed it and thought that was odd. If I had to do it over again I'd do it in a second. The sound alone is enough. A lot of people ask me if a 350GT ,yes I've got the ricey emblem , is a more powerful version of a G35 b/c it sounds so much better. And that's w/ the stocker tube. I've got to get a Z tube when I finish the rest of my mods. But like I said, I can't really comment on removing the resonator alone.
Old Jan 6, 2006 | 12:55 PM
g35rcr's Avatar
if the jwt had a better heat shield it might be a nice alternative to the stock box and k&n filter...that flemsy piece of aluminum foil doesnt do much to shield the heat out...
Old Jan 6, 2006 | 01:10 PM
MBentley's Avatar
It sounds better than the stocker though and given the minimal, if at all, difference in performance that's good enough for me. It's all about preference I guess. I prefer to physically hear a difference than to perceive a theoretical performance difference. Has anyone done a head to head dyno test on this?
Old Jan 6, 2006 | 01:45 PM
99atlantic's Avatar
Hmmm, i'm tempted to do it now ^_^
When i removed the power duct (part #5) it sounded AWESOME above 4k RPM. What i'm worried about it removing the air box's resonator will make it sound different, maybe quieter. Hmmm, i suppose i could always try
Old Jan 6, 2006 | 02:06 PM
ChicagoX's Avatar
Don't drink and Mag Race
That's exactly what the sonic change was for me: quieter.
I replaced it for a more "hollow" induction note.
Old Jan 6, 2006 | 02:14 PM
99atlantic's Avatar
your wording is confusing me (or maybe i'm just stupid and i just woke up, lol).....are you saying by removing the part from the bottom of the air box, it went quiter, or that the induction noise was hollower?
Old Jan 6, 2006 | 02:22 PM
ChicagoX's Avatar
Correct. When I took off the resonator and plugged the hole, the induction sound was quelled slightly.
When I replaced the resonator, the more desireable (to me) 'hollow' sound returned.
Old Jan 6, 2006 | 02:27 PM
99atlantic's Avatar
what happens if you took it off but DIDN"T plug the hole and just left it gaping there?
Old Jan 6, 2006 | 02:57 PM
ChicagoX's Avatar
You would lose the advantage of having a pressurized, sealed airbox.
Old Jan 6, 2006 | 03:06 PM
  #30
99atlantic's Avatar
hmmm,m i wonder how important that is? ^_^
