Removing the intake resonator (part #8)
Old Dec 29, 2005 | 11:14 PM
99atlantic's Avatar
ACtually, this is a ressurected topic from like 2 yrs ago, but most of the pics are fubared from the board move, so I figured maybe bring it alive again. It's the resonator at the bottom of the stock air box, serves as a water-catch-can for any water that makes it that far up (part #8)
Okay, so I see it's held on by 2 bolts......anybody removed it and wants to offer any advice on how to get those bolts free easily, w/o having to remove the front bumper, lol
Old Dec 30, 2005 | 09:18 AM
SilverII's Avatar
I removed mine. You have to basically remove #10 to get to it. It is quite simple actually.
Old Dec 30, 2005 | 10:02 AM
Slick 6MT's Avatar
So what are you eliminating? Has this been dyno-proven to gain any power?
Old Dec 30, 2005 | 10:07 AM
JaxGman's Avatar
Thats some serious over engineering...
Old Dec 30, 2005 | 10:20 AM
g35rcr's Avatar
make sure when you remove it to cover up the hole in the bottom of the intake box...it creates a vaccuum effect with the stock box...i used a plastic plug and glued it into spot...i drove around without plugging it up and it created a hollow sound
Old Dec 30, 2005 | 10:45 AM
Jtrain's Avatar
wow just buy a ztube for 50 bucks lol
Old Dec 30, 2005 | 11:34 AM
g35rcr's Avatar
the z tube has nothing to do with the lower resonator that is attached to the intake box...
Old Dec 30, 2005 | 11:46 AM
ChicagoX's Avatar
Don't drink and Mag Race
I run a z-tube with the resonator. I initially removed it and plugged the hole (with a shampoo lid and silicone, I believe ) but didn't like the induction sound.
Old Dec 30, 2005 | 12:45 PM
g35rcr's Avatar
i used a cap from a pack of weed wacker blades...used e6000 to hold it in place...chicago x btw where did you pick up the parts for you intercooler project
Old Dec 30, 2005 | 01:33 PM
badtziscool's Avatar
I don't get what the purpose of the water-catch-can is? There's no need to retain the water that makes it in that far. I would have thought a simple drain hole is all that's needed.
99atlantic's Avatar
About how far down is the bolt that holds #8 in place?
Old Dec 30, 2005 | 01:48 PM
maxpower's Avatar
I haven't see the older thread, but after looking at this I'm not sure removing the resonator just to add a 1" diameter hole to the airbox is worth the effort.
Old Dec 30, 2005 | 01:52 PM
99atlantic's Avatar
removing the power duct had an awesome effect on the sound, so I don't think it can hurt to remove that gangly piece from below
Old Dec 30, 2005 | 02:04 PM
maxpower's Avatar
i agree that there was a big difference in induction by removing the power duct , and that only took 30 seconds. this just looks like a lot more work
i take another look under the hood and see if I can find the bolt that needs to come out.
Old Dec 30, 2005 | 02:27 PM
99atlantic's Avatar
I looked yesterday and hence why i'm hesitating on it - to me, the only way I can see to get at it is if I remove the lower engine cover protector or take off the wheel and wheel-shroud. However, maybe if you do lift #10 straight up and out you can see/reach it.
