Exhaust for Z on G35 coupe........?
Old Dec 30, 2005 | 06:16 PM
G_Spot's Avatar
Ok I read through all the chatter on previous threads about fitting Z exhausts on G coupes but haven't come to a final conclusion. Is it safe to say it could be done with the 6" spacer and perhaps a little customization from the muffler shop with regards to the hanger placement?
Thank you,
Chris
Old Dec 30, 2005 | 08:30 PM
venommaxr33's Avatar
Must Go Faster!!
Is there a difference between the G200 exhaust for the 350z and G35 coupe...i found a place where i can get it but its for the 350z. will i need anything else besides the 8in extension for the exhaust?
Old Dec 30, 2005 | 08:40 PM
G_Spot's Avatar
i have no idea
-chris
Old Dec 30, 2005 | 09:39 PM
Triple8Sol's Avatar
If you get an extension piece, that will bring the muffler to about the correct position. However, with most (if not all) Z exhausts, the tips will be too short for the G. Likewise, a G35c exhaust will have tips that are too long for the Z, and they'll stick way out past the bumper.
Old Dec 30, 2005 | 10:22 PM
Destro's Avatar
Is there a difference in the exhausts? I have an almost brand new 350Z catback exhaust that I was going to try to sell. I might try to install it if there is a better difference.
Old Dec 30, 2005 | 10:38 PM
gary c's Avatar
The Z cat-back..............
I sold a Stillen cat-back system to a G35 pilot just
a few months ago. I kept in touch just to make sure
the install went as I had told him. All that was needed was the 6" extension. He also mentiond that
the system sounds "Sweet"! Oh yea, a muffler dude
that knows his $hit helps....... Cost should be
in the $100 range, not much more. You shouldn't
have to make any other changes....like tips.
Old Dec 31, 2005 | 02:04 PM
dannyboi2088's Avatar
dont buy the extension pipe
just go to a muffler shop and they will add the correct amount of piping to make it fit just right.......and they install on for you......i got it done for $100 because the car is a g35.........it really should be about $70
im in houston by the way so it maybe a little bit cheaper here but it shouldnt be over $140
Old Dec 31, 2005 | 04:56 PM
G_Spot's Avatar
ok i'll be ordering my exhaust soon. anyone have any GReddy Trust connections?
thanx for the help,
chris
Old Jan 2, 2006 | 02:47 PM
papagz's Avatar
i did that with my Tanabe exhaust. which is stil for sale DAMMIT! i had an 8 inch extension added on it and it fit pretty well. its the angled tip so you cant tell if they are short or not.
Old Jan 2, 2006 | 02:55 PM
SI_G35Coupe's Avatar
the Invidia G200 is a true dual exhaust..... 2 pipes from the cats all the way to the muffler... you would need 2 extension pipes, and the invida uses a weird piping diameter like 2.25" i think so the off the shelf one that Mynismo sells wont fit. it would definitely be cheaper and easier to get the G version
TWASkyliner
Feb 8, 2020 08:00 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
