MREV going on today ... reset ECU ??
Old Jan 31, 2006 | 07:49 AM
Bigguy2000's Avatar
Is an ECU reset a necessity or will it "re-learn" on it'sown once my MREV ion later today?
Wanted several opinions to get everyones input..... thanks!
Old Jan 31, 2006 | 08:11 AM
truplay8's Avatar
THE BATMOBILE
dont need to reset the ECU..........wait until you get more mods and then consider a TS reflash
Old Jan 31, 2006 | 01:09 PM
99atlantic's Avatar
it's not a big deal - just pull the battery overnight after you install it, hehe.
Old Jan 31, 2006 | 02:49 PM
drunkin master's Avatar
When you are installing the spacer, the instruction tell you to take out the negative battery connection. So that will do a reset for you anyway. good luck.
Old Jan 31, 2006 | 06:32 PM
Hydrazine's Avatar
After its installed, run your car WOT from ~2K RPM to redline a couple times.
Shut off the car. Remove the key. Start it back up and its ready to go!
Old Feb 1, 2006 | 12:04 AM
Bigguy2000's Avatar
Thanks all. Install went smoothly and it just so happened that the car got two WOT's immediately after install so things should be just about right. It will get a nice little road trip on Thursday.
Just put some Infinity Kappas up front so all "sounds" should be more enjoyale...........
On to the exhaust!
Old Feb 1, 2006 | 12:28 PM
99atlantic's Avatar
only if you take 24hrs to install it, lol ^_^
KallDay86
Jan 8, 2016 12:42 AM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
