5/16" Spacer Help Please!
Old Mar 8, 2006 | 02:31 PM
Strtsk8r321's Avatar
My MD 5/16" IsoThermal Spacer should be arriving today. I think I have everything I need except a inch/pound torque wrench. I only have a ft/lb. Will a ft/lb work or do I need to get an in/lb? Thanks, all help is appreciated.
Old Mar 8, 2006 | 02:35 PM
If that one wont work can someone tell me which on to get? I am looking at these: http://da.harborfreight.com/cpisearch/web/search.do
Old Mar 8, 2006 | 02:36 PM
Derek S's Avatar
the instructions are in ft/lb. peopel just use in/lb to get it more accurate.
if im not mistaking MD spacers are torqued to 5 ft/lb.
Old Mar 8, 2006 | 02:42 PM
Derek S's Avatar
you should PM ( Hydrazine ) TONY from Motordyne Engineering. he helps everyone with questions about his products.
Old Mar 8, 2006 | 03:00 PM
ok thanks!
Old Mar 8, 2006 | 03:47 PM
99atlantic's Avatar
RTFM....it tells you how to convert to the proper measurements.
Old Mar 8, 2006 | 03:50 PM
Ok I will RTFM when it arrives.
Old Mar 8, 2006 | 04:13 PM
99atlantic's Avatar
it's available online on teir website
Old Mar 8, 2006 | 04:20 PM
EricIsKlumzyee's Avatar
10ft lb
Old Mar 8, 2006 | 06:28 PM
Originally Posted by Klumzyee
10ft lb
Which one is it? 10 or 5?
Old Mar 8, 2006 | 06:46 PM
absolutg's Avatar
workin...
there are two different types of bolts you have to torque down i believe. check out the instructions online
Old Mar 8, 2006 | 09:26 PM
Derek S's Avatar
DUDE not 10 man, with stock bolts its 10 not with MD bolts. you'll brake the bolt with 10ft/lb.
O AND MAKE SURE YOUR PLENUM IS COLD IF ITS HOT YOU'LL HAVE A BETTER CHANCE OF BRAKEING THE BOLTS.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
