Got my 5/16 spacer today, But ???
Opened the box to find only the spacer. Isn't there suppose to be different size screws, etc with even the basic spacer?
Originally Posted by NickS
Spacers don't always come with new lugs/bolts. But yes, you need new (longer) ones to use with your spacers.
I was under the impression these were included, since the invoice says that as well. I can see this is already getting off to a bad start.
what vendor did you get the spacer from? you should get like 18 bolts : 4 long bolts, 3 medium length bolts, and 11 short bolts (for the perimeter), washers for all the bolts, and plastic 6 plastic spacers (goes between top and bottom plenum and acts as seals) all in separate zip-loc baggies stuffed into one ziploc baggie with Motordyne Engineering logo...
Originally Posted by jameyb
+1. When I received mine from Motordyne I was so impressed with the organization and packaging. It made everything so easy. Where did you order this from? This can't be right. You have to have the new bolts because the old ones won't be long enough once the spacer is in. Did you get a gasket as well or just the spacer?
It was bought from motordyne engineering! No separate packages with bolts,, etc... just the spacer, invoice and directions.
I called and left a message, but haven't heard anything back as of yet.
Update, got ahold of Tony and he is going to overnight the bolt package. He said it definately should have been included. First time I had spoken with him and very pleased with his willingness to correct the problem. I will give a review once I get the bolts and get the spacer installed.
Hahahahaha... I thought he meant WHEEL spacers.... Hahahahaha! My bad
I got the gasket. Hopefully the rest will be here tomorrow. I knew Nick was talking about wheel spacers when he said lugs/bolts. I just was going to bust him out.
Terry_G35
Sep 10, 2015 08:17 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
