Installed JWT POP charger, protect or move the ac line?
Old Jun 4, 2008 | 07:28 AM
  #61
g35_Smilie's Avatar
I'm so glad this thread is a sticky. I wouldn't have known about protecting the AC line if this wasn't a sticky. I just bought my JWT popcharger a few weeks ago and I recently installed it. I also got a Z-tube when I bought the p/c. Thank you for all the questions and answers everybody... (im still learning )
Old Jun 29, 2008 | 10:58 AM
  #62
MixturePinoy's Avatar
bump
this is very important. my line has a rubbed hole in it now.
i cant believe i missed this thread
Old Sep 27, 2008 | 05:31 PM
  #63
uf20wop's Avatar
will any wire loom do, or should i look for high temp stuff?
Old Sep 27, 2008 | 09:59 PM
  #64
05VAG35's Avatar
fit the G35
anyone know if pop charger from a 350z fit the G35??? thanks
Old Feb 1, 2009 | 01:44 AM
  #65
tiguy99's Avatar
Can't see why it wouldn't
Old Feb 1, 2009 | 04:10 AM
  #66
reservoirdog242's Avatar
i'm ordering a z tub/ popcharger, what is the best way to protect it, wire loom?
Old Feb 19, 2009 | 02:20 AM
  #67
Yosef's Avatar
I just checked and i have alot of clearence, at least 3 inches. Maybe my mechanice moved the stuff around but still glad this thread is hear for people who have problems.
Old Feb 20, 2009 | 11:32 PM
  #68
NaiveRapture's Avatar
THREE inches? Whiskey Tango Foxtrot? Yeah some stuff must have definitely been moved around!
I just put my JWT+Z on tonight, I'll have to go take care of the A/C line tomorrow afternoon, perhaps I'll go with some "engine bling" while I'm at it haha.
Old Feb 21, 2009 | 01:12 AM
  #69
Yosef's Avatar
I spoke to my mechanic and maybe my measuring is not the best but he said that he did move the things around to make sure nothing would rub but i measured today and its about 2 on the part that usually rubs. I'll try to get pictures up as soon as I can.
Old Mar 1, 2009 | 10:54 PM
  #70
Tollboothwilley's Avatar
Better fix than wrapping. Just space out the bolt that holds the z-tube to the plenum. That should be spaced the same amount as the plenum spacer. No rubber. 1/2" clearance here.
Old Mar 2, 2009 | 02:34 PM
  #71
EGDgyDor's Avatar
When I installed my Z tube, I protected that little AC line with a small piece of rubber fuel line split down the middle - easy
Old Mar 24, 2009 | 08:02 PM
  #72
chrischil's Avatar
i installed today...but its making "sweaking" sounds when i accelerate what did i do wrong...?
Old Apr 4, 2009 | 09:22 PM
  #73
EGDgyDor's Avatar
Maybe a loose clamp or rubbing somewhere; a shot of spray silicon might help locate the squeaky area...
Old Apr 5, 2009 | 06:12 PM
  #74
chrischil's Avatar
a shot...where?
Old Apr 6, 2009 | 11:02 AM
  #75
EGDgyDor's Avatar
...wellll that's a good question. I was thinkin any where you suspect it might be rubbing - to see if the squeak temporarily goes away. Spray just one area at a time to try and find the offending area. Just because I've never had to do this one myself doesn't mean I not an expert - and you can have a big lol on me when my AC line blows...
