Ok a little confused...MD spacer and lower plenum
Old Apr 21, 2006 | 01:45 PM
vmsturbo's Avatar
So i have a 05 5AT coupe, do i just need the spacer, or will i need the lower plenum as well. The threads i've been reading have just been confusing me since i see so many different answers.
Old Apr 21, 2006 | 02:23 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
I know it can be a pain. call the guys at MD directly and talk to them rather than get the info second hand. This is what I did becasue themore I read the more convoluted it became.
http://www.motordyneengineering.com/contactus.asp
Old Apr 21, 2006 | 02:29 PM
Foo_G's Avatar
BTW welcome to G35Driver. make sure you check on whether or not there is a local G club that participates on here.
Old Apr 21, 2006 | 07:45 PM
Andy2434's Avatar
Initially, the MotorDyne plenum spacer was the only MD product, which afforded the non RevUp engines any measurable gains. Aside from the ISO Thermal components, the MREV (spacer and pre '05 lower collector) and MREV Plus (spacer and modified pre '05 lower collector) were designed with the RevUp engine in mine. This combination affords the RevUp engines excellent gains. However, it appears that Tony at MotorDyne has tested the MREV Plus combo on non RevUp motors and has found that the said combo does afford the non RevUp motors some measurable benefits. From what I can understand, you can opt to choose the ISO Thermal MREV Plus option.
Here is the thread.
https://g35driver.com/forums/intake-exhaust/92810-mrev-installed-non-revup-engine.html
Old Apr 21, 2006 | 08:19 PM
tomcatm's Avatar
Here is the thread.
https://g35driver.com/forums/showthread.php?t=92810
So The Mrev++ is the spacer, and lower plenum modified version 2, and this modification is different that the mod for the Mrev+ lower plenum?
Old Apr 21, 2006 | 08:40 PM
Andy2434's Avatar
I have seen the MREV++ notation tossed around on these boards a few times, now. I have no idea what this is . . . If it is. I am very curious, to say the least. Too bad that Tony is out of town.
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Terry_G35
Sep 10, 2015 08:17 PM
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
