evo2 not loud enough for me...
Old May 15, 2006 | 10:49 PM
GLuXuRy's Avatar
Originally Posted by cutiewolf
ohhh my car is from michigan and have michigan plate on, i dont even need to have emission tests...
LUCKY
Old May 15, 2006 | 10:51 PM
cutiewolf's Avatar
i heard pro1 exhuast with header and test pipes on a g35 in person...
that sound its like a airplane....wayyy too loud
the reason i pick evo2 cause of the LOOK,and now i want it to be meaner
..wat test pipes do u think it would be nice combo with evo2? or wat test pipe is the "2nd" loudest.
ps..im not into change the headers
Old May 16, 2006 | 12:02 AM
cutiewolf's Avatar
about is the difference between test pipes and resonated? and wat does it mean by raspy sounding crap with test pipes?
Old May 16, 2006 | 12:04 AM
GLuXuRy's Avatar
rasp is cheap honda exhaust sound... its best to get the resonated ones
Old May 16, 2006 | 12:17 AM
cutiewolf's Avatar
wat resonated test pipes u think i go on with a buget condition?
ps...im into loud! meaner! sounds since my car dont need emissions...
Old May 16, 2006 | 12:21 AM
GLuXuRy's Avatar
i dont have test pipes so i couldnt recommend any... sorry... but i would search the fourms... i help out by searching too.. maybe someone will chime in with test pipes... if your on the G Squad im sure one of you bros can help ya on choosing one
Old May 16, 2006 | 09:01 AM
Rookie84's Avatar
Fast Intentions test pipes have the largest resonated section and supposedly have least rasp if any. It is more expensive than others, but I think it would be worth it for its quality. I'm personally doing the same setup pretty soon. I'll probably have everything done in June.
Old May 17, 2006 | 01:12 AM
cutiewolf's Avatar
looking for resonated test pipes..pm me if u have for sale!!
Old May 17, 2006 | 03:39 PM
cutiewolf's Avatar
Old May 18, 2006 | 02:04 AM
truplay8's Avatar
THE BATMOBILE
check the classifieds on here and my350z
Old May 18, 2006 | 02:37 AM
cutiewolf's Avatar
does anybody know anything about this resonated test pipes?
http://www.intensepower.com/inmorerapi35.html
anyone who has them please share some of ur experiance
Old May 18, 2006 | 12:02 PM
WhiteSkylineSF's Avatar
i got GReddy EVO2 also . . . and so does my cousin . . . i've had an exhaust company custom make it a true dual . . . after that the car sounded meaner than my cousins . . . and now i have kinetix hi-flow cats . . . sounds even louder . . . more aggressive . . . the moment the engine was turned on we all noticed a difference . . . i'll start a thread soon about the SSV Extreme intake manifold . . . dyno n everything . . . let me just get everything together . . .
Old May 18, 2006 | 12:04 PM
also got sound bites and video from day at the dyno . . . not exactly sure how to get them on here . . . any help would be cool . . . PM me . . . thanks . . .
Old May 20, 2006 | 01:28 AM
ISMSOLUTIONS's Avatar
Testpipes
Hey all -
Here's the scoop - from some real world testing:
In the world of testpipes - you choose from resonated or non resonated. When you go non-resonated, you WILL get rasp throughout the system, UNLESS, you heavily resonate the rest of the exhaust to counteract the pulses and balance the backpressure - thereby killing the rasp.
The resonators slow the exhaust just enough to make this balance happen without sacraficing performance very much at all. With this said, not all resonated pipes are the same and not all resonators are the same either.
1 - the diameter of the pipe makes a huge difference - any real testpipe should be done in 2 1/2 to maximize performance and system stoutness.
2 - the resonator - every version out there will have a 4"-6" resonator on the testpipe. The shorter the resonator, the more rasp potential. From what I have found in my research, the resonators are spiral louvre cores - just like the old fashioned glasspack mufflers (they are still made that way as well and definately have their place - I'm not at all knocking them) - BUT they are restrictive and not very efficient either. A PERFORATED CORE RESONATED TESTPIPE will give you a much smoother sound in the end, far less potential for rasp and more efficiency.
3 - Fast Intentions Resonated Testpipes are perforated cored units. They are also 8" resonators - not 4"-6" in size. The efficiency of these units is all the way through the band - through redline. This means that after 4000-4500 RPM the system will not start to rasp out - the resonator keeps working all the way through. This isn't so with most of the testpipes. I forget which set it was, but one of them actually made it to 5800 RPM's before it rasped out. The problem is that you'll never hear it unless your outside the car...you know - all the people who your trying to impress will hear it
As much as I want to not try to sell you the Fast Intentions testpipes, and educate you on your choices...it's hard to do that when the FI testpipes are the only ones made this way - and they are competatively priced.
We have a Group Buy going on now in the MarketPlace for our Intimidator Exhaust system, and the testpipes are also on sale there.
You can get more info as well at http://www.fastintentions.com and the other thread here at https://g35driver.com/forums/intake-exhaust/91857-you-asked-tease-first-looks.html
Marlin84
Apr 1, 2020 12:52 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alinero718
Sep 27, 2015 09:35 PM
1Typhoon
Sep 25, 2015 08:45 PM
