bat overlays diy.help needed
Old Jun 13, 2006 | 01:39 PM
ebuy929's Avatar
hjey guys i have a g35 coupe
i went throught 3 sets of bats tailight overlays and i cant seem to get them on right
i follow all the steps but i stil experience bubling and most of all creasing
i dont want to get ti professionaly installed because i like saying i did it myself
can anytone post some pix or diy instruction
help needed asap i got a new set to put on
Old Jun 13, 2006 | 01:59 PM
spirogyro's Avatar
if you would of had a pro tinter do it, you wouldn't of needed to buy 3 sets.
Old Jun 13, 2006 | 02:21 PM
LjN_728's Avatar
^+1 Bat's overlays are what...$40 a pair, so you spent $120 when it would've only costed you between $25-40 at the pro tint shop. Maybe Bat himself will chime in and give you pics
Old Jun 13, 2006 | 02:25 PM
madchef's Avatar
Run a search, cause there are a bunch of postings on how people like to put them on.
How exactly did you try to put them on? Let us know so we can figure out where you went wrong
Old Jun 13, 2006 | 02:57 PM
ebuy929's Avatar
well i used soap and water then lined them up and used heat to make it sit properly but they dont sit right
Old Jun 13, 2006 | 03:15 PM
GT-Ron's Avatar
Are you using the full overlays or the GTR3 type with the cut-outs? If it's the GTR-style, I'd say your problem is likely that you aren't cutting them where needed. I didn't realize they needed it until it was too late as well. Trimming will probably give you better results, as you won't be having to try to shrink so mutch and keep everything lined up.
FWIW, I did take my second set to a vinyl-sign shop for installation. The guy had a hard time between trimming and shrinking. Eventually, he got them to fit pretty good with a little overlap (which I wasn't happy with). The big problem is that he didn't have the patience after all of that to get all of the bubbles out and, contrary to his belief but very much in line with Bat's instructions, the bubbles didn't bake out. I had ostrich-skin overlays. Too many bubbles to pop, so I pulled them off and will instead paint the housings to achieve the appropriate look.
Old Jun 13, 2006 | 03:22 PM
ebuy929's Avatar
i actually am using the gtr overlays i didnt install them yet
i cut the old ones but not cuz of excess film just to line them up but u can notice all the cuts
Old Jun 14, 2006 | 02:41 AM
Blue_Batmobile's Avatar
Official Sponsor of the Florida G35 Club
Smile
Here's a guide to applying my Overlays :
http://www.scionlife.com/forums/viewtopic.php?t=34653
On my hgtr3 kit where there is a seam at the bottom, simply take an xacto knife and apply just enough pressure to cut off the overlap ! Do this when it dries completely. As far as air bubbles go, what you need to do when applying them is work from the middle of the overlay to the outside. There are quite a few threads on hear that show how people have done the install with success. Do a Search. Also remember, when you first place the Overlay onto tyhe surface, it's not going to appear to line up. Ofcourse not! It's not a flat surface. But as you slowly work the Overlay down, you'll notice how everything lines up nicely .
As far as him paying $120 for 3 sets. I highly doubt that. I'm good at giving pretty good discounts on 2nd sets . In fact most of the people that do need another set actually only need one piece because they figured it out after applying the 2nd piece!
Bat™
Old Jun 15, 2006 | 06:12 PM
ebuy929's Avatar
thanks bat
but the scion life tutorial on the z is different
the z overlays are much easyer i still need help with the gtr g35 tails overlay
Old Jun 17, 2006 | 05:03 AM
pm your contact info to me. I'll call ya .
Bat™
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
socalg35x
Aug 7, 2015 09:36 AM
bjo16
Aug 4, 2015 09:52 AM
newg37
Jul 26, 2015 09:32 AM
