grille removal
Exterior Modifications ; Interior Modifications ; Lighting ; Gauges and More
grille removal
Oct 31, 2003 | 12:03 PM
PinoyG35
Oct 2003
Maryland
grille removal
has anyone removed/replaced the 2 bottom front grilles. How did you do it?
PinoyG35
Find all posts by PinoyG35
David's 2007 G35 Coupe Build Thread
09:26 AM
DIY: Remove Gas Pump to Clean Sending Unit & Clear P0463 Code
RemmyZero
V36 DIY
11:13 AM
David's IP G35 Coupe
Picture Share
12:41 PM
Extreme Dimensiosn is Hiring an Automotive Shaper.
Extreme Dimensions
Southern California
06:28 PM
Sticking Caliper Issue
dcsbh1
03:15 PM
Tags
diy
g35driver
grille
removal
Back to Subforum
View Next Unread
Aero Kit Under Body Ground Clearance
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
04:39 PM
