Mesh grill, attachment??
I know kits like GReddy and the SP grill etc use little metal wires bonded to the fiberglass, and you use this to secure a grill onto the kit.
My question is, what kind of epoxy is used to bond the wires to the fiberglass? The reason I ask is cuz I had my GReddy sides painted and the body shop kinda broke a couple of the metal wires off. I tried using a hot glue gun, but that doesn't stick to the resin. What should I use?
You can also use the 6 or 7 minute 2 part epoxy that comes in a Syringe type dispenser. It dispenses the proper amounts of Part A and Part B. Mix up both parts and apply. Just make sure you buy the right formula for your application.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
jb weld works too if you don't want to buy the whole can of bondo.
