hid?
Old Apr 12, 2007 | 08:38 AM
skystyle's Avatar
Cool hid?
is it posible to change out just the bulb or do i need to replace the balast if i wanna upgrade to 8500k?
Old Apr 12, 2007 | 08:42 AM
Callaway's Avatar
Just the bulbs, just like if you were changing out stock ones. I don't wanna start any debate on this, but you sure you want to go that high? Your visibility, especially in the rain will go down a lot.
Old Apr 12, 2007 | 01:31 PM
BadBoy06's Avatar
they will "Look Cool" but function like as$
Old Apr 12, 2007 | 11:34 PM
Beebo's Avatar
who the hell is the person on the forum that drives with 10,000K?
Old Apr 12, 2007 | 11:39 PM
redlude97's Avatar
The one in the ditch
Old Apr 12, 2007 | 11:53 PM
cutiewolf's Avatar
heres wat u looking for?
yes ur visibility will go down, but your reflect from road signs will go up...
i think mine is more than 8000k ..i think its 10 or 12k ..its so blue...
BTW...i took out my LEN COVER ...
EDIT: one time i was behind my gf's car about at least 1 mile away,she called me and known i was behind her...lol
Old Apr 13, 2007 | 12:52 AM
redlude97's Avatar
thats called glare buddy, way to be an a-hole to all the other drivers on the road.
Old Apr 14, 2007 | 06:58 AM
skystyle's Avatar
who makes a good one. i wanna match the leds in the bumper.
Old Apr 16, 2007 | 02:22 PM
JJKK's Avatar
i just got myself a set of 8000K last week
it looks super cool alrite, but i did lose some visibility
weird thing that when i had 8000k on my last car (RSX-S), the visibility was better than what i am having rite now.... is it becoz of the housing or something??
Old Apr 16, 2007 | 03:11 PM
redlude97's Avatar
You are mistaking glare for visibility. Installing HID kits into halogen housings results in light scattering all over the place including above the cutoff which you are interpreting as "better". While this is occuring you are blinding every other car on the road because of your hotspots and major glare issues.
Old Apr 16, 2007 | 03:29 PM
JJKK's Avatar
hum... that might be the problem, however i never had anyone highbeam me or showing any sign that i was blinding them thou....
but anyways, if i knew i would lose this much visibility, i would get the 6000k instead 8000k.
Old Apr 16, 2007 | 03:40 PM
IvoryGT's Avatar
basically..at 8000K you are about 1000 lumens less than 4300K that means you lose about 1000 square feet of lighting area...is all that blue worth your life?
Old Apr 16, 2007 | 03:43 PM
redlude97's Avatar
thats with a decent 8000k bulb as well, and lumen output varies so much between all the crappy manufacturers that you will likely lose even more than 1000 lumens. Stock output is 3100-3300lm, philips ultinon 6000k is 2400lm, which are considered the "best" of the 6000k bulbs. 8000k and up and you'll be in the 2000lm or lower range. Thats like losing 30%+ of your stock output
Old Apr 21, 2007 | 05:28 PM
brianC131's Avatar
it basically lik dis.. higher tha K, u lose more visibility as u go up.. i have 10000K on mine.... i luv it cuz its a tru blue.... i got mine at
www.pilothid.com.......only $97 jzt for tha bulbs i wanna see u guys beat dat price...actually if u do let me kno..
Old Apr 21, 2007 | 09:19 PM
IvoryGT's Avatar
^is this guy a ninja that has night vision?
