Help! Tryin to Remove Grill
Old May 7, 2007 | 08:11 PM
alphamatt's Avatar
Exclamation Help! Tryin to Remove Grill
tryin to remove my stock grill, got all the top rivets off, but theres these two side connectors that i cant seem to cut loose
anyone got a quick fix for me?
much appreciated
Old May 7, 2007 | 08:12 PM
GLuXuRy's Avatar
PM caskyline .. but i saw him do it once .. theres lil tabs i believe that you can see between the grill slits .. i think he used a long skinny flat head
but im not 100% sure Matt ..sorry
Old May 7, 2007 | 08:15 PM
alphamatt's Avatar
theres some sort of latch keepin it from comin and i am so tempted to yak it out haha, be prepared for some blacked out grill action.
anyone else out there! my hood is open waitin for them wise words
Old May 7, 2007 | 08:21 PM
Triji's Avatar
If I remember correctly... its been awhile, the 2 on the sides just go into a small opening... try one side at a time and push gently in twards the center of the grille on the sides and pull forward since it is also connected by tabs on the bottom... slide twards you...
Old May 7, 2007 | 09:11 PM
Calvin's Avatar
Overglorified Altima
there are 2 square clips (1 on each upper corner) which look like <->. You need to turn the 2 square clips so they look like [\]
use a flathead screwdriver
Old May 7, 2007 | 09:27 PM
LILShiraz's Avatar
can you take pics of how to take it off, unless its too late
Old May 7, 2007 | 09:45 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
you cant really take pictures of what you have to do. Just take a flathead screwdriver and push the tabs on either side so they go through the hole... it's pretty self explanitory.
-GP-
Old May 7, 2007 | 09:53 PM
alphamatt's Avatar
thanks guys! grill is lookin good so far couldn't have done it with out the 'driver
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
vQFamily
Sep 30, 2015 01:17 PM
