Coupes with NISMO front Need your help
Old Jul 10, 2007 | 01:27 PM
JOKER's Avatar
CLUB MODERATOR
I need a favor from you guys
Could anybody take a picture underneath the car so I could see how you guys attached the bumper to the car.
That's all.
If someone will do that for me I'll send you a $.
Old Jul 10, 2007 | 01:28 PM
savefatkids's Avatar
did you get the bumper from klymzee? becase on mine i only attached the middle to the underpanel.
Old Jul 10, 2007 | 02:01 PM
JOKER's Avatar
CLUB MODERATOR
^yes I got it from Klymzee
Were you able to attach to where the stock bumper attaches ?
Old Jul 10, 2007 | 02:58 PM
JOKER's Avatar
CLUB MODERATOR
No One Wants A Dallah?
Old Jul 10, 2007 | 03:19 PM
afr0puff's Avatar
Supa Dupa Moderator
The bumper attaches to the car mainly by the two bolts/screws using the OEM plate by the sidemarkers. You'll see what I'm talking about when you take off the bumper.
There is nothing underneath the bumper for it to attach to. Instead, the black plastic under body cover attaches to the bumper to stay on the car. Those covers need the bumper. The bumper does not need anything else but those four bolts by the sidemarker.
The rest is just for stabilization, not support.
Calvin's Avatar
Overglorified Altima
i ziptied my old nismo bumper to the plastic undertray. some people have made custom extensions.
Old Jul 10, 2007 | 03:25 PM
afr0puff's Avatar
Supa Dupa Moderator
THis is the best I could do while at work. There should be holes along the bottom of the bumper that line up perfectly with the holes on the OEM bumper. You use the same brackets/bolts from the OEM bumper to hold the plastic undertray in place.
Old Jul 10, 2007 | 03:31 PM
Calvin's Avatar
the poly nismo fronts that i have dealed with were shorter on the bottom. the plastic undertray would not reach the bottom of the poly nismo bumpers that i've seen and thus zipties/custom extensions were used.
Old Jul 10, 2007 | 03:35 PM
JOKER's Avatar
CLUB MODERATOR
the stabilization is what I'm worried about
I don't want to look like some retarded ricer with a bumper that wobbles in the wind
Old Jul 10, 2007 | 03:38 PM
the bottom part on my bumper extends back so it attaches directly to the plastic cover on the bottom. no modifications were made. i just used different bolts
Old Jul 13, 2007 | 02:07 PM
EricIsKlumzyee's Avatar
just line up the bottom engine cover with the bumper and drill and attach. You'll need to use new bolts/clips or transfer existing clips over but you do not need to modify or extend the cover.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
yoyoyo8
Aug 12, 2015 03:04 AM
newg37
Jul 26, 2015 09:32 AM
laksjd84
Jul 24, 2015 05:12 PM
Kz_Ed
Jul 23, 2015 02:41 AM
