trunk problem
Old Jul 29, 2007 | 07:05 PM
Topvega's Avatar
trunk problem
I was not sure where to post this but I have a problem and could use some help from anyone who might have had the same problem or from anyone who has any ideas. I don't know why but I can not get my trunk to open. None of the electronic openers work. I need to know if there is a way to get the back seat down so I can at least try to pull the emergency cord to open the trunk. Thanks for any help or ideas.
Old Jul 29, 2007 | 07:16 PM
m@rky's Avatar
hmm i just made a thread about this. i have the same problem.
Old Jul 29, 2007 | 08:17 PM
silvernole12's Avatar
Are you sure the on/off switch in the glove box wasn't switched to off?
If you shove your hand between the seat bottom and the seat back towards the middle...there is a red strap. That strap releases the seat back. Then from there you can climb in the trunk pull the emergency cord.
Old Jul 29, 2007 | 10:09 PM
burns420's Avatar
i had this problem to. i use the red strap. it happened around december 06 for the first time, they said it was loose wiring and fixed it under warranty. about three months later i took it in again for the same thing. they said it was a different loose wire. fixed it under warranty. it happened again 2 weeks ago and i got them to look at it when i was getting an oil change. they told me it was yet another loose wire and would cost 250 to fix(car is now out of warranty). so i guess infiniti does not guarantee any of their repairs and they dont look to hard for other possible problems. that was 401/dixie infiniti in toronto by the way. i didnt get it fixed from them, im going to call infiniti this week and see whats up
tal1412
Nov 28, 2022 09:25 AM
derres
Aug 28, 2015 03:27 PM
Jusseth
Aug 24, 2015 05:24 PM
mryogi
Aug 20, 2015 04:10 PM
Fireman07603
Aug 9, 2015 06:00 PM
