Removal of Rear Spoiler
Old Sep 10, 2007 | 10:46 PM
tonyzito's Avatar
Can anyone tell me how to remove the rear spoiler on the 2004 G35 Sedan? I can remove the two nuts that are visable from the trunk, but cannot get to the two plastic bushings that are directly above the rear lights.
Old Sep 11, 2007 | 02:31 AM
Joe_Camel's Avatar
Did you try taking the rear lights out? (or maybe you did and that's how you can see the bushings?) I installed mine myself and it mounts with 4 screws, no plastic bushings that I can recall. Really long flathead screwdriver to push them through the top maybe? Hope that helps.
Old Sep 11, 2007 | 02:55 AM
ttrank's Avatar
Grocery getter
Not sure about the factory installed one. I put mine on myself and it was 4 screws.
Old Sep 11, 2007 | 07:14 AM
tonyzito's Avatar
Thumbs up
Thanks, but I did take out the back lights to see the plastic bushing. I finally got the spoiler off. There is a two sided tape gasket that holds the rear of the spoiler to the trunk lid at each end. There is also a snap type of fitting that slides into the plastic bushing on each end of the spoiler that unsnaps once the two sided tape is cut away. Bottom line, you just need to gently lift the front of the spoiler away from the car and use a razor to cut the two sided tape as you lift on the spoiler. If anyone needs a picture of the bottom of the spoiler and the snaps on the trunk, please respond and I'll provide one. Success!!!!!
Old Sep 12, 2007 | 08:03 AM
03G35SPORT's Avatar
yes could you post a pic of the bottom . thnaks
Old Sep 19, 2007 | 07:45 PM
tonyzito's Avatar
Pictures of bottom of spoiler
Here's the pictures. Hope this helps
Attached Thumbnails Removal of Rear Spoiler-dsc00975-1-2-.jpg   Removal of Rear Spoiler-dsc00976-1-2-.jpg
Old Sep 19, 2007 | 07:53 PM
Jeff92se's Avatar
Red Card Crew
Reason for taking it off? BS color right?
Old Sep 21, 2007 | 07:32 PM
tonyzito's Avatar
Reason for Removal
16 y/o daughter backed into a mailbox. Needed to have spoiler painted
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Jul 27, 2015 05:25 AM
