Removing Emblem
Old Sep 17, 2007 | 02:23 AM
u4528010's Avatar
Removing Emblem
What is the best way to remove emblem? I want to remove "INFINITI" at the back. Thank you
Old Sep 17, 2007 | 02:25 AM
ckp's Avatar
ckp
use the search feature to search "debage"
Old Sep 17, 2007 | 02:32 AM
u4528010's Avatar
Thanks
Old Sep 17, 2007 | 02:41 AM
j 4 lD's Avatar
no, you spelled it wrong lol. its "debadge"
Old Sep 18, 2007 | 05:12 PM
EuG35's Avatar
Yeah you should search it but basically heat it up with a hairdryer and saw behind the emblems with strong dental floss, if you use weak stuff it'll break when you're doing the infiniti logo, very easy. But the hard part is to take off the adhesive ****. Use Goo Gone, rub it on, let the adhesive absorb it, then try to take it off.. I used a firm rubber spatula to take it off worked well for me.
Old May 11, 2008 | 06:23 PM
broke_as_ajoke's Avatar
finger nail polish will also remove the glue
Old May 11, 2008 | 06:27 PM
O HELLA OEM's Avatar
do what EuG35 said....
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
