Rear Bumper Problem ><!!!
Old Dec 30, 2007 | 10:52 PM
Roguewolf's Avatar
So i was shaving my trunk yesterday and noticed a TINY scratch in the back of my bumper ... when i get up to do something i tend to get **** about everything. So being the idiot that i am i decide to go buy a touch up kit from the dealership and fix it.. so i try the pen roller and that didn't work out that well so i decide to use the brush. I did the base white and and let it dry and then another coat of white and wait 24 hours then do the glossy *ivory pearl* final coat and ..well.. it REALLY didn't blend as a matter of fact i kinda made it twice as big/noticeable.. i'm a ****in idiot... is there any way i can fix that... cuz i really don't wanna repaint a whole bumper for a inch and a half.. i shoulda just left it alone.. it wasn't even noticable ANY help would b greatly appreciated.. id take pics but it's dark out..
-Rogue
Old Dec 30, 2007 | 10:56 PM
doctorG's Avatar
haha. try rubbing compound to try and rid the area.. or mask the surroudning area and wetsand it out.
Old Dec 30, 2007 | 10:57 PM
sfgr415's Avatar
I never liked touch up paint. It is so noticeable.
Old Dec 30, 2007 | 10:58 PM
Roguewolf's Avatar
>< im an idiot lol. I dont even feel like goin to work tomorow, id much rather go find a way to fix that ****. wth am i gonna repaint it w if i wetsand??
Old Dec 30, 2007 | 11:07 PM
Roguewolf's Avatar
i kno, talk abotu noticeable, **** is a total different shade.
Old Dec 30, 2007 | 11:34 PM
xjonmo's Avatar
pics?
Old Dec 31, 2007 | 12:05 AM
07-6MT's Avatar
properly touching up paint on a car isn't as quick and painless as most think or want, to properly touch-up do the following:
-apply primer(if metal is visible)
-then paint(carefully, the idea is getting the new paint even with the
surrounding paint, multiple coats may be needed
-then carefully wetsand(to smooth out and get rid of the high spots)
-then buff the area
the wetsanding and buffing smooths and helps 'blend' the area. if the paint isn't a perfect match this step makes it not nearly as noticeable. if the paint is a perfect or near perfect match, you should not be able to see it at all after this step.
hope this helps, remember to just take your time - if you rush it will only look worse
Old Dec 31, 2007 | 12:13 AM
Roguewolf's Avatar
so i should westand it.. cuz it just looks like it's ..."bumpy"... i don't know it's like a smudge on the car.. sort of the same color just stands out when u look at it in at diff angles.
Old Dec 31, 2007 | 12:36 AM
07-6MT's Avatar
it stands out at different angles because its not smooth - shadowing from light( sun, light bulbs, etc.)
start with something like 800grit(check to make sure it can be used for wetsanding) and carefully try to sand just the 'high-spots', once its some what smooth then go to 1000grit(and go a bit beyond the touched-up spot) and keep working on it until the touched-up spot is smooth with the surrounding paint then you are ready to buff - if you have never buffed before i suggest you don't make you first attempt on your G!
when wetsanding keep and eye on the paper, it can clog up fairly easily - get a bucket and put water in it along with a few drops of liquid detergent(something like dawn or joy), the detergent keeps the paper from clogging as easy
keep a smooth steady pressure on the paper, and go in a back and forth or up and down motion, no circlular motions!
now get to work and take and post up some before and after pics for us!
tiguy99
Mar 1, 2016 11:42 AM
st33zygill
Jul 29, 2015 10:05 PM
T.Y.M1210
Jul 29, 2015 11:53 AM
