Quarter Panels
Old Jan 13, 2008 | 07:35 PM
Ralph's Avatar
Quarter Panels
I need someone's help. I was hit by a damn Seqouia on Friday and I need a new quarter panel...
Does anyone know where I can order one?
Old Jan 13, 2008 | 08:38 PM
mwarsh1's Avatar
most of the time on a g35 you dont replace the quarterpanel, you fix xit in a body shop with some body filler material (bonda) and paint it. cqall the parts department on monday. if itsdamaged very badly you might have to buy a salvage rear clip to replace it\, just take it to a body shop..... good luck.
Old Jan 13, 2008 | 08:45 PM
Calvin's Avatar
Overglorified Altima
How bad was the hit?
The QP is a PITA to repair.
This repair set me back $1k.
Old Jan 13, 2008 | 09:58 PM
jigahus's Avatar
Sequoia did a tree fall down on you? But ya take it to a
Old Jan 13, 2008 | 10:21 PM
GreenGoblin's Avatar
The goblin resurrection
It is an expensive are to repair cause they not onl have to fix the metal and prime it but have to paint or blend the entire quarter
Old Jan 13, 2008 | 10:26 PM
citymunky's Avatar
It could be fixed, I got hit by two golf *****, and my wife hit a wall (it looked like O RLY damage). I paid a little over $400 at Carsmetic in Jacksonville, Fl. (They have a set flat rate per panel no matter what's the damage.)
Old Jan 13, 2008 | 10:35 PM
Calvin's Avatar
Assuming the work is good, that's a fantastic deal depending on the damage!
Old Jan 14, 2008 | 11:12 PM
EuG35's Avatar
Talk to Jason@Riverside he might have it, he has a lot of different car parts
Old Jan 15, 2008 | 01:30 PM
AccordinlySlo's Avatar
That qt doesn't need to be replace. It would be a lot cheaper just to pull it out and fix it rather then replace the qt. Replacing a qt panel can cost up to 1k. Hope that helps
Old Jan 16, 2008 | 04:51 PM
citymunky's Avatar
I think the work was great, I can't tell where the dents where, they did a good job blending in the paint, no orange peel at all.
Flat Rate FTW!!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
G35xdriver04
Nov 7, 2015 08:31 PM
leo38cheng
Sep 29, 2015 05:43 PM
