how do i take the stock grill out ??
Feb 9, 2008 | 12:18 AM
i took the black pins out of the top but its still connected at the bottom and i cant figure out how to get it out.
Reply 0
Feb 9, 2008 | 12:34 AM
literally you can pull it out by pushing each of the plastic pins(?) outward...the outside pins have an edge but you can push them out with a little force. very easy to do
Reply 0
Feb 10, 2008 | 01:23 AM
There are obviously the top 4 clips. Then, there are the tabs that hold the grill to the bumper. However, there are 2 "tabs" that you have to turn with a flat head screwdriver. They are located in the upper corners of the grill between the top and second bar. Twist them so the go from <> to []
Reply 0
Feb 10, 2008 | 01:52 AM
I figured it out, the bottom clips were a real pain in the ***, thanks guys!
Reply 0
Jun 14, 2008 | 01:12 PM
So is the sedan 2005 grill different? I see 6 tabs across the bottom and I am shoving on them extremely hard while trying to also pinch them but I am having no luck. Any thoughts as to what I am doing wrong? Besides probably being impatient...
Reply 0
Jun 14, 2008 | 01:22 PM
it's probably the same.. the pins hold the grille in place pretty well, so just keep trying.. i found that putting a flathead screwdriver in there and pushing them above/below the grille, i can't remember, as I pulled it came out alright.
Reply 0
Jun 14, 2008 | 01:24 PM
Okay, thanks, I'll give it another shot.
Reply 0
Jun 19, 2008 | 02:18 AM
I got it - thanks for the help! I went all black - looked too "Rudolph the Red-Nose" when I left the Mt. Fuji logo chrome...
Reply 0
Jun 19, 2008 | 02:23 AM
i would have painted it matte blue or something to match the car, but whatever makes you happy
Reply 0
Jun 19, 2008 | 01:53 PM
My plan is to paint the headlight casings black as well and get some 19" black wheels with a polished lip. I'm thinking that it will actually work pretty well once it is completed.
Reply 0
Jun 19, 2008 | 04:29 PM
i cant get my grill out... iv been trying for 3 days now... im doing it wrong...
Reply 0
Jun 19, 2008 | 04:59 PM
^ make sure you take out all like 6 pins or w/e on the top of the grille.. then with quite a bit of force + screwdriver, lift/pull the tabs at the bottom of the grille till it comes out.. search for ionic grille installation thread and itll show you how to do it
Reply 0
Jun 19, 2008 | 05:10 PM
Super easy... 4 clips to remove and 4 push clips inside.
Reply 0
Jun 20, 2008 | 01:07 PM
Quote: i cant get my grill out... iv been trying for 3 days now... im doing it wrong...
It might help if you get that fox out of your way.
Reply 0
Jun 20, 2008 | 01:17 PM
Quote: ^ make sure you take out all like 6 pins or w/e on the top of the grille.. then with quite a bit of force + screwdriver, lift/pull the tabs at the bottom of the grille till it comes out.. search for ionic grille installation thread and itll show you how to do it
Iv tryed and i know about the diy... i still cant get it out...
Quote: It might help if you get that fox out of your way.
Damn thats maybe the problem...
Reply 0
