Wing Removal Help
Old Mar 23, 2008 | 12:39 PM
05GCOUPE6MT's Avatar
Wing Removal Help
I need Information on how to remove the rear wing on my 05 G35 Coupe. My friend is giving me a great price to repaint the trunk due to a scratch, However I need to remove and reinstall the wing myself. Are their any parts that may get damaged during the removal process {Like a seel} that I should order.
Old Mar 23, 2008 | 04:58 PM
Beebo's Avatar
take off the trunk lining u can see all the screws/bolts and clips that need to be removed... you will also need to heat up around the spoiler with a heat gun or hair dryer to soften the 3M tape thats holding it on as well
Old Mar 23, 2008 | 09:04 PM
Thank You- Is there a seal? What keeps the water from entering the trunk through the holes?
Old Mar 24, 2008 | 02:16 AM
Beebo's Avatar
Yes.
Old Mar 24, 2008 | 10:53 AM
Originally Posted by Beebo
Yes.
First off Beebe-Thank you so far for all your help. Does this seal need to be replaced. Is likely to get damaged during the removal of the wing. Is the seal GLUED down or does it just sit in place. I want to have everything I need to reinstall the wing before I take it off.
Old Mar 24, 2008 | 11:56 PM
Beebo's Avatar
im not sure i think the seal is more like a glue type but i really dont know... call and ask your dealer or PM Tony@RiversideInfiniti or Mike@RiversideInfiniti and ask one of them...
good luck!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
