Another Hood Hinge bending problem
Old Apr 21, 2008 | 01:11 PM
binar's Avatar
Not looking for any solutions. I have already purchased two new hood hinges from Tony @ riverside.
I have an 03' coupe. My passenger side hood hinge has bent to the point that it takes two people to open the hood. The passenger side sits about 1/4 lower then the drivers side. SUX!
Anyway, will spend my time removing my fenders and replacing both hinges. I figured as long as I was at it I might as well replace both.
I can't believe the hood hinges BEND! WTF??? I have owned about a bazzilion cars in my life. I have NEVER had a hood hinge bend. Oh well....
I just wanted to post so that others would be warned/alerted... LUBRICATE YOUR HINGES.. that is all.
ohh and
Old Apr 21, 2008 | 09:54 PM
LT1 SS's Avatar
I recently had a hinge problem where the hood would scrape the fender. The hinges were replaced under warranty.
Old Apr 21, 2008 | 09:56 PM
GreenGoblin's Avatar
The goblin resurrection
ya i just bought a new one
Old Apr 21, 2008 | 10:12 PM
simpson's Avatar
do you have to take the fender off? (i think dont hold me to it) i think that you can just take the cowl off its only a couple clips and take your wipers off and you can get to the bolts. i do it at work all the time i will have to go outside and look at my car.
Old Apr 23, 2008 | 10:59 AM
binar's Avatar
It would be fantastic if I didn't have to remove the fender. Reading previous post I assumed I had to. I'll def check out if I can get to the bolts w/o removing the fender.
Old Apr 23, 2008 | 12:38 PM
RST531's Avatar
how much did the new hinges cost??
Old Apr 23, 2008 | 07:46 PM
binar's Avatar
About $20 each from Riverside.. not much
Old Apr 23, 2008 | 08:46 PM
RST531's Avatar
Thanks!
Old Apr 24, 2008 | 09:19 PM
binar's Avatar
np
Old Apr 24, 2008 | 09:25 PM
I was told that the fender did not need to come off I hope that is the case
Old Jul 26, 2008 | 01:09 PM
elrooko's Avatar
Guys this is happenind to me as well. Does anyone know how to replace the hinges?
Old Jul 27, 2008 | 08:23 AM
elrooko's Avatar
Anyone know how to replace the hinges? I really need to do this ASAP...thanks guys!
Old Jul 27, 2008 | 08:32 AM
you need to take the fender off no way around it
Old Jul 27, 2008 | 08:34 AM
elrooko's Avatar
Ah shiiiit. Are you sure?
Old Jul 27, 2008 | 09:08 AM
ya did mine about 2 months ago
