Wetsanding & Buffing Small Objects
Old Apr 28, 2008 | 11:43 PM
bigc's Avatar
Wings Nation
I need to wetsand & buff a few small plastic parts that I just painted. I think it would be difficult to use a PC / buffing wheel on them when it comes time to buff them so is there anything else I can use? Are microfiber polishing towels OK or are there special polishing rags/towels/sponges for stuff like this? any help is much appreciated - thanks!
Old Apr 28, 2008 | 11:49 PM
speedracerg35's Avatar
buffing out wet sanded areas usually require a fairly high speed buffer. you can do it with a pc, but it would imagine it would take a long time. depending on how small the pieces are, i would suggest a dremel with a polishing head, or maybe you can try a mother polishing ball.
Old Apr 29, 2008 | 05:00 AM
Scrooge's Avatar
They actually make small pads then 3 inch. If you have smaller parts to polish.
Old Apr 29, 2008 | 10:24 AM
bigc's Avatar
Wings Nation
thanks guys, these are some great suggestions
any other ideas?
Old Apr 29, 2008 | 10:34 AM
04Gwhiz's Avatar
use a dremel with the polishing bit
Old Apr 29, 2008 | 10:41 AM
naughty240's Avatar
There is a brand called CIA they make a small air powered variable speed polisher. Comes in a nice case. Then you can get the small hookit pads for buffing back the shine
some 3" pads here. http://www.tcpglobal.com/detailsupplydepot/dsd9.aspx. They have a ton of sister sites for paint, supplys, and anything else you would need.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
