badging gialla
Old Jun 6, 2008 | 08:50 PM
firstg35's Avatar
badging gialla
i tried searching this but didn't find much. how do i install a badge on my gialla grill? i think i'm going to put the nismo badge in the corner to match the rear. then again i may not.
maybe the same nismo badge as i have in this pic
Old Jun 7, 2008 | 12:30 AM
Roguewolf's Avatar
def not feelin the nismo on the trunk... at all.. looks too busy.. my 2 cent. however if u wanna put somethin on the grill other than the infiniti i suggest u put the "350GT* but then u'd need to put skyline badging all around. also.. to install a bagde use double sided 3m tape the super heavy heavy duty *red tape* had mine holding up my infiniti logo for about 7 months no probl.
Old Jun 7, 2008 | 09:38 AM
firstg35's Avatar
yeah, you may be right. it does look a little busy. i may remove that. the 350gt may look the best, but i want to keep the infinity. so i guess it looks like i'm gonna go with the infinity in front. i wonder how it would look if i took the nismo off the back and put it up front in the corner? i haven't seen that yet.
this was my first idea...
wich one looks best?
Old Jun 7, 2008 | 10:01 AM
Mr Inkredibul's Avatar
Fuji symbol FTW but only if you remove the Nismo in the back. It's too busy. Or remove everything from the rear except the Nismo and put the Nismo on the right side instead of the left.
Old Jun 7, 2008 | 11:34 AM
firstg35's Avatar
well then, fuji it is. so you think tape is a good way to keep it on the grill?
Old Jun 7, 2008 | 11:38 AM
MikeYo's Avatar
i epoxyed mine because it fell off once and someone took it once.... now it not going anywhere and if i want to get rid of it i just need to change the mesh.
Old Jun 7, 2008 | 11:41 AM
firstg35's Avatar
i will try the epoxy. thanks.
Old Jun 7, 2008 | 02:08 PM
kernel's Avatar
SEC > Big 12
+1 to all of this
either way, remove the NISMO from the trunk. If you go 350GT on the front, rebadge the trunk.
Old Jun 7, 2008 | 04:23 PM
firstg35's Avatar
well then. consider it gone.
Old Jun 9, 2008 | 07:55 PM
firstg35's Avatar
what about removing the g35, and moving the nismo over like this:
Old Jun 10, 2008 | 12:41 AM
Roguewolf's Avatar
i think nismo letterin look off on a G.. altho i got a nismo license plate
Old Jun 10, 2008 | 12:44 AM
Calvin's Avatar
Overglorified Altima
Do it the same way you did it on the trunk..
Old Jun 10, 2008 | 04:53 AM
The-Dream's Avatar
How much does the emblem cost from the dealer?
Old Jun 10, 2008 | 06:26 PM
Beebo's Avatar
That looks ok
Old Jun 10, 2008 | 06:31 PM
BlueDevilBAMF's Avatar
I would go with just Mt. Fuji front, just Mt. Fuji rear.
