How to prep bumper for painting.
Old Aug 9, 2008 | 09:35 PM
Andrei's Avatar
What do I need exactly to remove the paint and get it ready for paint. I want to prep the bumper for the body shop before they paint it.
I read sand paper. What type?
I read solvent. What kind and where from?
Anything else?
Old Aug 10, 2008 | 12:01 AM
Solekeeper's Avatar
DA It off.
Is there any damage to it?
If not, continue to cleaning it with a pre-paint cleaner.
Tack it.
Paint
Clear.
And why are you prepping it if you dont mind? Isnt this why your taking it to a body shop?
Old Aug 10, 2008 | 12:22 PM
Mannyz33's Avatar
Anything else?
Don't remove the paint!
Take a 400 grit sand paper and wet sand the bumper with a consistant flow of water ( garden hose ). your only trying to create a some what course surface for the primer to attach to.
Repair any scrathes, pin holes....etc
Primer
Wet sand primer
These are the basics there is a bit more detailed info in regards to prep work.
If you really want to this PM me
Old Aug 13, 2008 | 07:52 PM
Andrei's Avatar
Primer
Wet sand primer
I wanted to prep it and let the body shop spray it.
I ordered painting supplies today to paint it myself since I want to know how it's done.
This is what I ordered.
I'll wet sand the bumper. Apply one coat of primer after. Apply 1 coat of paint. Wet sand again after it dries. Apply a final coat of paint and let it dry. Than put on 1 coat of clear.
Does that sound right?
Old Aug 13, 2008 | 09:49 PM
Mannyz33's Avatar
No not exactly.
Concerned about the paint and clear coat coming in a 12oz spray can????
I can tell you automotive painting is nothing like buying a can of spray paint and going at it.
In a vague nut shell.
Base coat is the paint which will need a reducer in order to be reduced ( thinned out a bit for better flow ) That goes according to the paint manufacture specs.
Clear is obviously the clear coat which a activator is applied ( hardener )
This should be sprayed with a HVLP automotive spray gun
Process basically is to wet sand bumper, spray your primer, wet sand primer, look for and fix and problem, re primer if need be and re wet sand.
Spray your base coat then clear coat.
This is not something that is easily learned nor is it something easy to follow under a brief DIY. You should practice, practice first on scrap material first.
Not to mention not all paint manufactures come out with a really good paint match just by paint code. Trust me
Sherwin Williams as a good line of paint that I bought for my Z, My Z was SS as well. If anyone needs the details let me know.
I would leave it to a professional.
Old Aug 13, 2008 | 09:53 PM
Mannyz33's Avatar
Anyone else having issues with the site right now
Old Aug 13, 2008 | 10:43 PM
Andrei's Avatar
Ya it's hardly loading.
I guess I'll drop it off at the body shop and let them do it. They use Sherwin Williams paint.
I'll still use what I ordered to repaint the front license plate cover on the sedan Aero bumper since that cover comes off. If that goes well I'll repaint the front bumper
Old Aug 13, 2008 | 10:56 PM
Mannyz33's Avatar
Here is the label on the can I have
Sherwin Williams
Ultra 7000 code WV2
B7-62220 00(G)
U7203 Larg Metalic
U7204 CRSE Metalic
U7206 SM BRT Metal
U7271 Effect Additv
U7046 UHS Blue
What you want is There Ultra 7000 line of paint
Old Aug 27, 2008 | 12:39 PM
Andrei's Avatar
Sherwin Williams
Ultra 7000 code WV2
B7-62220 00(G)
U7203 Larg Metalic
U7204 CRSE Metalic
U7206 SM BRT Metal
U7271 Effect Additv
U7046 UHS Blue
I appreciate that. I'll order exactly that next time.
I got my paint today and I'll try it on the front license plate cover.
Old Oct 8, 2008 | 02:15 PM
Andrei's Avatar
On Monday morning I spotted a Sherwin-Williams rig on I-85N Kind of interesting I saw it when I did because I was thinking about repainting the hole car.
Old Oct 9, 2008 | 11:20 AM
visibiliti's Avatar
add a drop and some new sideskirts on and you've got a clean lookin' rig...
Old Mar 12, 2009 | 06:45 PM
KING ROCKS G's Avatar
Paint g advice
I have a scratched bumper that needs work like sanding, priming and painting.. Can you give me instructions on the procedure please? Am talkin from sanding the one I bought used to repainting my car color and all! Thanks!!
Primer
Wet sand primer
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
Jyounya
Sep 12, 2015 04:03 PM
Jyounya
Sep 12, 2015 02:29 PM
