More LEDS this time noone else has done this.
Old Apr 15, 2009 | 03:35 PM
  #46
PhillyG35's Avatar
^^^^^^I'm probably using about 12 of these: http://www.superbrightleds.com/specs/FLS.htm
per headlight
Old Apr 15, 2009 | 05:02 PM
  #47
ct350g's Avatar
Originally Posted by PhillyG35
Ok, I'm a beginner with this, can anyone give me the rundown on how to wire an LED strip to the existing wires and battery? Thanks alot.
you have a few options but I prefer to wire mine seperate into a toggle switch.... this way u can turn them on and off as a standalone to your headlight switch (as most led's dont work well with the heat of the D2S bulbs) wiring them is pretty easy....or .... you can splice into your city driving light wires and turn them on and off like that, but they will be on with your headlights as well and might burn out much quicker. I am putting together a DIY for wiring these etc .... PM me if you need any advice etc before i post the DIY (I have a ton of pics and diagrams)
Old Apr 16, 2009 | 05:32 PM
  #48
hollowch's Avatar
thank you soooo much!!! man ive been looking for a DIY on this for a long time. when do you expect to have it up?
Old Apr 16, 2009 | 06:42 PM
  #49
ttrank's Avatar
Grocery getter
Looks very clean.
Old Apr 17, 2009 | 01:38 PM
  #50
heyu's Avatar
a DIY would be great....i have been looking a long time for a DIY for the city lights
Old Apr 21, 2009 | 08:33 PM
  #51
Slvr G35's Avatar
^ +1
Old Apr 22, 2009 | 01:40 AM
  #52
lilindienplaya's Avatar
Originally Posted by Slvr G35
^ +1
im doing another mambers lights maybe next week, ill try to do a writeup
Old May 19, 2009 | 05:04 PM
  #53
bmpnride's Avatar
For those of you who are using the flex strips around the projector, what do you use to cover up the tiny wiring and letters inbedded within the strips? I was thinking of painting over this with silver paint so it blends in with the shroud. From all the pics I have seen, I cant see any of the raw guts of the strips. While the strips are the easiest, I may end up installing individual LEDs into the shroud itself. All these lights look good guys....
Old May 19, 2009 | 08:11 PM
  #54
Mashimarho's Avatar
Originally Posted by BlackOutG
here is mine
OMG Those are ILLLL
Old May 27, 2009 | 01:58 AM
  #55
mac178's Avatar
Originally Posted by RST531
looks sick.
you need to finish the look with some clear corners with the same mod.
co sign
Old May 29, 2009 | 02:02 AM
  #56
Shincrono's Avatar
Old Jun 27, 2009 | 10:00 PM
  #57
Terry35's Avatar
Were can I find a diy write up for this mod?
Hasanbaloch
Feb 29, 2024 08:45 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
itschuckster
Jul 25, 2015 08:07 AM
