New LED Brake Light Bulbs
Old Jul 21, 2004 | 06:14 AM
  #31
G35_51's Avatar
Re: New LED Brake Light Bulbs
Yes, you're right. When I only had LEDs in the rear, I used a 10 ohm, 10 watt resistor. After adding LEDs to the front as well, I'm now using a 4 ohm, 50 watt on each side that handles front and back. As far as the light output is concerned, it's not quite as much as the original bulbs but I'm happy with them. In bright sunlight, they're a little dimmer, but I'm happy to sacrifice that for the "snap on/snap off" characteristics of the LEDs.
Old Sep 26, 2004 | 01:01 PM
  #32
roneski's Avatar
Devil's Advocate
Any updates or impressions from anyone using these? Also does the front amber turn signal use the 7443?
Ivory Coupe 5AT
Z tube, K&N drop in.
Fujitsubo Catback
Old Sep 26, 2004 | 08:53 PM
  #33
G35_51's Avatar
The front amber is a 7443 (dual filament) while the rears are 7440 (single filament). I have them installed and I like the way they look. True, they're not quite as bright as the original incandescents, but they're good enough for me.
mike730
Jan 12, 2018 04:25 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
